Thermostat ? - Mustang Evolution
Old 06-04-2013, 04:43 PM   #1
WhiteCobra94's Avatar
Thermostat ?
Is it bad to take out the thermostat during summer months ? I have noticed that my car is running hotter now then winter and just trying to see if removing the thermostat will help keep it cooler or will it hurt it?
Old 06-04-2013, 07:29 PM   #2
Billymich's Avatar
Did you install it backwards? That could do it.
Old 06-04-2013, 08:46 PM   #3
No it's been in since last April I just have noticed that the temp is higher then normal
Old 06-04-2013, 09:41 PM   #4
watson 1025's Avatar
If you remove it you will never get to proper operating temperater. Mine ran a little hot in the summer so I upgraded to a griffin aluminum radiator. No prob since. I've had a few buddies buy the ebay 3 core aluminum and were happy with em.
watson 1025 is offline   Reply With Quote
Old 06-06-2013, 08:18 AM   #5
mustangmania91's Avatar
My opinion only, an upgraded radiator is a great idea. 3 row especially. Will always run slightly cooler.
mustangmania91 is offline   Reply With Quote
Old 06-06-2013, 05:11 PM   #6
92coupe's Avatar
I've got the sve 3row and love it its a bit cheaper and you will definitely notice a difference
92coupe is offline   Reply With Quote
Old 06-06-2013, 05:22 PM   #7
Where did u get yours from?
Old 06-06-2013, 05:47 PM   #8
92coupe's Avatar
Late model restoration
Old 06-06-2013, 07:55 PM   #9
Lapida's Avatar
Do you have a SCT chip?
Set the fan to turn on the low speed at 180.
Lapida is offline   Reply With Quote
Old 06-07-2013, 07:10 AM   #10
Yes I do.
I don't think I can go with a 3 row I may have to go with a 2row because of clearance from my radiator fan and my pulleys there's only a 2-3inch space now
Old 06-07-2013, 08:36 AM   #11
92coupe's Avatar
Are you running the factory fan?
Old 06-07-2013, 09:12 AM   #12
I went with a 2 core and it was set back only a half inch farther. When you find one you want get the dimensions then measure the thickness from ur rad support back.
Old 06-07-2013, 10:06 AM   #13
another thing I would recommend is some new radiator brackets that allow for more movement. I went through two mishimoto radiators before I realized. I don't have subframe connectors or anything to stiffen up the chassis, so I think all the flexing caused the small leaks. I then noticed that they make upgraded brackets to deal with this I believe. Just wanted to point it out. Overall I did like the increased cooling.
Adam302gt is offline   Reply With Quote
Old 06-07-2013, 03:46 PM   #14
Ok I'll check that , it's been raining like crazy the last two days so either tomorrow or Sunday I'll get some measurements .
And yes is a factory fan , I was looking at a few new ones but I'm not sure what CFMs to go with idk what the stock fans CFMs are.
Old 06-07-2013, 06:52 PM   #15
Radiator could be getting old, your tstat could be sticking... I'd replace it with a 180 degree unit and see what happens. You also really don't know what your temperature is if you are relying on the stock gauge.
Old 06-07-2013, 07:20 PM   #16
I can't remember what stock cfm is but I bought the flex a lite syclone s blade. It blows 2500 cfm and its been perfectly fine!
Old 06-08-2013, 08:45 AM   #17
92coupe's Avatar
I've got a new water pump the 3core radiator and just a junk 14inch electric fan set at 180 with a 180 degree thermostat and even in west tx (already been 110 this year) my car doesn't even hit midway on the factory gauge
Old 06-08-2013, 11:45 AM   #18
He has a 94, they have electric fans.
Old 06-08-2013, 07:09 PM   #19
Oh yeah, my bad!
11:53 AM
