1995 mustang gt rough idle - Mustang Evolution
Old 06-04-2013, 10:02 PM   #1
Region: Nevada
i have a horrible idle and recently had my car checked on a snap on brick for free and all of my sensors were reading good but i have a horrible idle and found a leak at my lower intake gasket and replaced the gaskets and now i am getting a p0172 and 176 which is o2 sensor both banks lean. the maf sensor is a remanned one that came with the car, and its not running lean cause im getting 11 afr.
flatstanley1 is offline   Reply With Quote
Old 06-22-2013, 04:22 PM   #2
540i6e39's Avatar
It could be throwing the code when you drive
540i6e39 is offline   Reply With Quote
Old 06-26-2013, 12:38 PM   #3
Region: Nevada
I have an update! where the oxygen sensors meet the main harness well that part of the main harness the wires were all melted together so I repaired that and it runs like a different car now I need a ford maf and she should have a clean bill of health. I'm getting maf voltage low and high which I believe is giving me my lean and rich codes
Old 06-26-2013, 01:11 PM   #4
94gtconvert's Avatar
After you fix everything, unhook the battery negative terminal for like 45 minutes. After that let the car idle for 5 minutes, a fact about our 94 to 95 sn95's is the 5.0 has a more advanced computer with adaptive learning so the car detects how the engine is responding when it adds or subtracts fuel. Your car should run a little rough for those 5 minutes. That's why are cars are so hard to tune with a high duration cam, the computer has no clue what's going on an why it needs more fuel than usual.
94gtconvert is offline   Reply With Quote
Old 06-26-2013, 03:36 PM   #5
Region: Nevada
okay will do thanx for the input, I'm going to get a ford maf on Friday!
03:09 AM
