junkyard intake - Mustang Evolution
Old 06-09-2013, 09:22 PM   #1
Jar72's Avatar
junkyard intake
So yet another issue arises from previous owner. No gaskets at all. Just rtv. Any ways does anyone have a good picture set or video of changing to the explorer intake. It was already done but after all the other issues I want to make sure it was done right.
JMF
Jar72 is offline   Reply With Quote
Old 06-10-2013, 07:26 AM   #2
93slowstang's Avatar
Your best bet is to get a haynes manual for your car. The explorer intake install will be about the same as the H.O. intake.
Old 06-10-2013, 10:46 AM   #3
I'd recommend the Chilton's its way more detailed than the Haynes. Honestly the Haynes is pretty terrible... Or go all out and get a factory HELM manual. The Chilton's I used had all the torque values and patterns.
And also, you are SUPPOSED to use RTV on the ends of the intake in place of gaskets. The gaskets suck even the rubber ones, the cork ones are about useless. If the guy did RTV for ALL the gaskets like around the intake ports and everything... yeah you need to get some gaskets in there lol. Just make sure to use RTV on the ends and RTV around the water ports.
Here are some install pics when I did the one on my rebuild:
THIS is the stuff you should be using, available at any parts store
RTV around the jackets
Cut off some bolts to use as guide studs and make sure you get the other side of the water jackets too
Make your end gaskets like yea
Installed. Again, make SURE you torque it properly and do it in the right pattern. Its all in the Chilton's manual. You'll probably have to go over the torque a few days later after a few heat cycles also.
Old 06-10-2013, 07:04 PM   #4
Jar72's Avatar
Awesome what about the plenum. (Upper Intake) lines and connectors.
JMF
Old 06-10-2013, 07:10 PM   #5
It bolts on just like it comes off, there is a torque pattern for it too and make damn sure you follow it because those aluminum intake threads WILL blow out if you don't use a torque wrench. No RTV or anything required for it, just the gasket and the torque wrench and bolts. Take pics when you take off the original intake of how all the vac hoses and all that junk went so you can put it back together although I had mine apart for awhile and remember it being pretty self explanatory.
Old 06-10-2013, 10:02 PM   #6
Jar72's Avatar
Thanks. Just finished removing cleaning and replacing injectors and o rings. 2 questions. As I'm not the one who originally put out on. 1 there is a vaccum line from the back top of the block and it is running straight to the upper intake. Is that right? 2. No egr. Is there a mod or something for that or run without it?
JMF
Old 06-16-2013, 08:41 PM   #7
That's the pcv (positive crankcase ventilation) good idea to have that on, I know smoke comes out of the dipstick if you don't have it together lol idk what or if it hurts anything if you don't have vacuum on it.
93lx5.0 is offline   Reply With Quote
Old 06-16-2013, 09:50 PM   #8
86gt's Avatar
Yeah if you don't have the PCV hooked to vacuum oil will come out of the hole and burn on the motor...
---------- Post added at 10:50 PM ---------- Previous post was at 10:50 PM ----------
And it'll smoke like crazy
86gt is offline   Reply With Quote
Old 06-17-2013, 08:56 AM   #9
Jar72's Avatar
Thanks guys. I got most of it figured out just waiting to purchase an intake adapter elbow. Those ain't cheap.
JMF
Old 06-22-2013, 04:17 PM   #10
540i6e39's Avatar
Summit lol
540i6e39 is offline   Reply With Quote
Old 06-23-2013, 04:04 PM   #11
wc3john's Avatar
You sir are a genius for the studs to hold the gasket in place while you place the lower intake down... I cannot begin to express my thanks for that idea! Should save several curse words during the next time I pull an intake.
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 06-23-2013, 11:10 PM   #12
Jar72's Avatar
I agree awesome idea will definatly do the is when I build my next engine.
JMF
07:49 AM
