Anybody done a 5 lug swap? - Mustang Evolution
Old 06-16-2013, 09:35 PM   #1
Not sure whether I want to or not but the idea of 5 lugs seems pretty cool lol. I've been told that I could use two short axle shafts out of a 8.8 ranger axle with 28 splines and they'd fit in my axle housing, idk if that's true? I got a lot of other things I should probably do first lol but figured I'd see if anybody else has found anything to work.
93lx5.0 is offline   Reply With Quote
Old 06-16-2013, 10:07 PM   #2
86gt's Avatar
If you check out the stickies up top by the threads....it will tell you everything you need to complete the swap!
---------- Post added at 11:07 PM ---------- Previous post was at 11:05 PM ----------
From what I've read and heard, it's much easier to buy a full swap kit from a place like LRS because it contains everything all in one kit and you won't have to source parts from different places.
86gt is offline   Reply With Quote
Old 06-16-2013, 11:01 PM   #3
Ronn501's Avatar
Region: Arkansas
Yea I have done the 5 lug swap from the ranger for my vert.. The rear end u will need the axels out of will b from 1983-1988 driver side axels... And make sure u don't pull your s clip out of your spool it's a real bugger to get back in
Ronn501 is offline   Reply With Quote
Old 06-16-2013, 11:13 PM   #4
Ya I've done a few sets of clutch packs on a few ford trucks, prybar/screwdriver and a lot of cursing worked for me lol, what'd you end up doing for the front?
Old 06-16-2013, 11:20 PM   #5
Ronn501's Avatar
Region: Arkansas
Well on the se truck I just pulled the dust cap off unscrewed the castle nut and the rotor came right off but I'm going to upgrade to a cross drilled and slotted here shortly
Old 06-16-2013, 11:26 PM   #6
I think I pulled the axles out some while I put the clip in, something I did made it a lot easier the second time I did it, I think that was it, then I rolled the spiders in after I got the clip in, just figured I'd mention that lol i think there the same setup. Idk yet lol
Old 06-17-2013, 07:52 AM   #7
Just a FYI from experience. When pulling axles on fords you should always remove your speed sensor so you dont damage it. The axles have a tendancy of not coming out without the sensor being removed or broken.
DieselStang is offline   Reply With Quote
Old 06-17-2013, 09:34 AM   #8
Diesel stang, off topic but is your stang really diesel? Lol
Old 06-17-2013, 11:37 AM   #9
No but one of my buildup sheets is for a T444E powered SN. So you could say possibly in the future yes I will have a diesel stang. Im trying to make as many build sheets as I can so when the time comes for me to buy my 7th stang I will know which build I can do for which amount of money I muster. Ive been bench racing for a long, long, long time.. Currently Im working on a all motor sleeper combination, its a Boss 302 based 357. The cam for it is also a Lunati. Voodoo Hyd Roller Cam - Ford 351W 302HO 292/300 - Lunati Power
Anywho, whatever I build next will be a 9 second car and 8 second capable.
Old 06-17-2013, 11:40 AM   #10
Venomouz831's Avatar
Off topic but what are the benefits of a 5 lug conversion?
)02 Gt, Founder of WE2G
Old 06-17-2013, 12:03 PM   #11
Ability to run different wheels is the primary reason people convert. Also people convert to run bigger brakes. Hardcore racers convert due to 5 lugs hold your wheels on better than 4 lugs..
Old 06-24-2013, 11:39 AM   #12
I'm in process of finishing up a 5 lug conversion with rear disc. I used a complete 8.8 axle from a 95 (rebuilt with 4.10's) for the front I did complete spindles from a 2001 gt for the larger dual piston calipers. I did my conversion for additional wheels better breaking and slightly wider track width for a wider tire in the rear. Doing mine was very easy and cost effective since I found all my parts at a junk yard minus a few brand new parts ( Hoses, Rotars, Caliper Hardware and Pads)
96 F150 Eddie Bauer
10 Focus
87 Mustang GT
08 Aprilia SXV 550
mcdonaldnick is offline   Reply With Quote
Old 06-26-2013, 11:52 AM   #13
Foxbody_Girl's Avatar
Really wanna do this to my 89 vert (: let me know how it works out for you!
Foxbody_Girl is offline   Reply With Quote
Old 06-26-2013, 05:09 PM   #14
93slowstang's Avatar
Speed sensor is in the trans not the rear end so how would you break it?
Old 06-26-2013, 05:17 PM   #15
I went the junkyard method for mine. More than pleased with the results. If thats the route you choose make sure you bring a list of what you need and the cars theyre on so you dont forget anything.
Old 06-26-2013, 09:45 PM   #16
Ya I think I'm probably going to go to the junkyard when the time comes, half my car is from there lol I think that sensor diesels talking about is for the abs, pretty sure it's a hall effect sensor, on my buddy's ranger it had a bunch of metal stuck to it and it was pointed at a wheel with a bunch of notches on it so im assuming that's what it was.
09:53 AM
