ltd firing order - Mustang Evolution
Old 06-17-2013, 09:55 AM   #1
watson 1025's Avatar
ltd firing order
I bought a short block that came out of a 1990 ltd along with a tfs 1 cam, gt40 heads and intake and a bunch of other stuff for it. But I read that the firing order is different. So does that mean that a cam for a 5.0 HO will not work in a non HO 5.0? Because I'm thinking it will open the valves at the wrong time. I'm just wondering if I will neexd a crank out of a 5.0 HO.
watson 1025 is offline   Reply With Quote
Old 06-17-2013, 10:16 AM   #2
86gt's Avatar
You don't need a different crank, even with a tfs cam the firing order is still 1-3-7-2-6-5-4-8...
---------- Post added at 11:16 AM ---------- Previous post was at 11:12 AM ----------
On any 5.0 engine you can make it a high output with a cam change and hydraulic roller lifters and spider hold down...but if its a block with flat top pistons certain heads will not work unless the pistons are fly cut for the valves
86gt is offline   Reply With Quote
03:54 AM
