5.0 build progress - Mustang Evolution
Old 06-20-2013, 10:50 PM   #1
93_FoxBody's Avatar
5.0 build progress
Just got back home from basic training Monday. Decided to do a little part shopping for the build. Started looking around for turbos here is why I bought for the build. Turbo is a Godspeed t67 and cxracing intercooler kit.
ID:	114961   Click image for larger version
93_FoxBody is offline   Reply With Quote
Old 06-21-2013, 10:13 AM   #2
DustyStang306's Avatar
Man that will be nice iv been thing on getting a hellion kit for my just got to get it painted and do the t box reinforcements and I'm going to get a set of umi lift bars for the back before I get the kit and I'm going to need a tko 500 or 600 because my stock t5 is on it's way out now haha
DustyStang306 is offline   Reply With Quote
Old 06-21-2013, 12:02 PM   #3
93_FoxBody's Avatar
The hellion kits are nice. I'm piecing together a nice turbo set up myself instead of buying a cheap kit don't have money for a hellion lol. I'm staying with a c4 automatic trans brake value body.
Old 06-21-2013, 03:41 PM   #4
Ye if your going for the best times auto is the way to go and if you don't mind me asking..how much are you going to have in it? And what HP numbers are you hoping for and at what psi?
Old 06-21-2013, 03:48 PM   #5
93_FoxBody's Avatar
Money in the turbo kit or the whole build?
Old 06-21-2013, 04:12 PM   #6
In the turbo kit
Old 06-21-2013, 04:19 PM   #7
93_FoxBody's Avatar
The turbo was 328 the intercooler kit was 529 all I need left is turbo manifolds wastegate and oil return lines. It's gonna be right around 1600-1800.
---------- Post added at 04:19 PM ---------- Previous post was at 04:18 PM ----------
I'm wanting at least 450 rwhp 460 rwtq at 15lbs of boost.
Old 06-21-2013, 07:05 PM   #8
Lapida's Avatar
15psi is too much for the 302 production block, from 6 - 10 psi would make you happy. Go with 15psi or more only if you have the 351w, world, dart or boss 302 block. What you have for tuning?
Lapida is offline   Reply With Quote
Old 06-21-2013, 08:26 PM   #9
No, if he's running a bone stock longblock he'll need to cram more air into those junk E7 heads to make them produce. All depends on the combo.
The intercooler you got is ok, that turbo... it is a garbage Chinese turbo and that particular brand has documented issues. You have been warned.
Old 06-21-2013, 09:02 PM   #10
93_FoxBody's Avatar
It's not bone stock at all. I've got cam gt40 heads ported values springs retainers gt40 intake ported. I know with people with the same turbo and been doing fine with there's and I've got a holly efi stand alone I'm using.
Old 06-21-2013, 09:09 PM   #11
They have balance issues as do most chinese turbos. It could be fine, it could fly apart and puke its internals right into your intake. The least expensive turbo I would buy would be a MP70 honestly...
I'm sure you are not going to sell it and buy a better turbo and just run it. I wish you the best of luck but I will not be surprised if I see a "what do I need for a rebuild?" post by you in a few months...
Old 06-22-2013, 05:01 AM   #12
Lapida's Avatar
I have the garbage Chinese turbo on my setup without any problems so far. With 8psi the power is amazing using gt40 heads and intake. 15 psi is more power than the production block can handle even using the best forged internals on the market. You can use 42 or 60 injector, 340 aeromotive fuel pump, blow through maf, one step colder plugs, new o2 sensor, wideband, 17 -21 total timing and upgrade the brakes That's just my recommendation. Good luck!
Old 06-22-2013, 05:42 AM   #13
93_FoxBody's Avatar
It's should be fine just as long as I'm not pushing over 500hp. If not i got another block ill use lol. But thanks hopefully it will be done soon
Old 06-22-2013, 02:41 PM   #14
540i6e39's Avatar
And tuning
540i6e39 is offline   Reply With Quote
Old 06-22-2013, 06:43 PM   #15
93_FoxBody's Avatar
Originally Posted by 540i6e39 View Post
And tuning
What you mean and tuning
Old 06-22-2013, 06:58 PM   #16
540i6e39's Avatar
You need tuning right?
Old 06-22-2013, 08:52 PM   #17
93_FoxBody's Avatar
Yea. It's gonna get tuned.
06:33 PM
