Speed density - Mustang Evolution
Old 06-26-2013, 05:46 PM   #1
Region: West Virgina
Speed density
Hey everybody need some help I have a pretty much stock 88 gt 5.0 I want to convert it to mass air has anybody done this before any advice would help
Mustangnutz is offline   Reply With Quote
Old 06-26-2013, 07:22 PM   #2
DustyStang306's Avatar
http://www.musclemustangfastfords.co...n/viewall.html this has all you need to know
DustyStang306 is offline   Reply With Quote
Old 06-27-2013, 01:34 AM   #3
Ok thanks
Old 06-27-2013, 09:01 AM   #4
351stroker's Avatar
I did the conversion twice. And about to do one more. It's a bit time consuming as u need to make a wiring harness(use wire loom, looks original) you will need to deem the wires through the firewall using the stock harness location, remove your old ecu and then need to swap a few wires around in the master plug but be careful. I had a few wires "jump" out and if I didn't have the manual I woulda been fooked! I bought my ecu and mass air meter in a kit and the provided the pin connectors. You will need 3 or 4 factory pin connectors. If u can't get any use the ones for the thermactor pump and components. Takes a bit of reading.
351stroker is offline   Reply With Quote
Old 06-27-2013, 04:55 PM   #5
Ok thanks for the advice
Old 06-30-2013, 06:51 PM   #6
Billymich's Avatar
I have a full conversion kit, MAF, ECM and pigtail that I never used, from racingfiveology. Let me know if you're interested
Old 07-01-2013, 09:29 AM   #7
351stroker's Avatar
How much?
Old 07-01-2013, 12:43 PM   #8
How much u asking man
Old 07-01-2013, 01:12 PM   #9
Billymich's Avatar
Idk it was like 300 from the site. I'd say 200 + shipping
Old 07-01-2013, 03:13 PM   #10
87mustangGT's Avatar
I got the full harness ecu and meter for 125 online so id shop aroun it pays off
87mustangGT is offline   Reply With Quote
Old 07-01-2013, 03:28 PM   #11
Billymich's Avatar
1986-88 FORD MUSTANG 5.0L MASS AIR CONVERSION KIT
I got the $350 one but I did not buy the filter, I have never installed or used any of the products, still have original shipping box. Either way just let me know.
07:31 PM
