Car makes a weird sound... - Mustang Evolution
Old 07-03-2013, 08:20 AM   #1
wc3john's Avatar
It sounded like it was coming from the back, so I popped the differential cover and saw this
It doesn't appear like anything is broken and the car drive like normal before I popped the cover yet still hearing the sound...
Any ideas? If it sounds like gears but isn't, what else?
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 07-03-2013, 09:27 AM   #2
do you have the proper fluid in there? with the friction modifier? or it could be the disks getting bad...
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 07-03-2013, 09:30 AM   #3
wc3john's Avatar
Well it had never been popped before I did it yesterday do I'm assuming it was the factory fluid.
And the posi unit has been doing one tire fryers...
Old 07-03-2013, 11:04 AM   #4
Four Eyes's Avatar
What kind of sound? Clunk? Whine? Rattle?
1986 GT with the typical poor boy mods. 3.73s, Hurst short throw, King Cobra Clutch with aluminum quadrant, lowered two inches on Eibach springs, Hopefully adding some heads and a decent intake soon!
Four Eyes is offline   Reply With Quote
Old 07-03-2013, 11:16 AM   #5
351stroker's Avatar
Prob need to replace the clutch pack. Funny sound is because its probably slipping like crazy from being worn out.
351stroker is offline   Reply With Quote
Old 07-03-2013, 01:18 PM   #6
wc3john's Avatar
Found the problem... Driveshaft bolts were loose... It was a stock driveshaft so it's a little weird...
Old 07-03-2013, 03:30 PM   #7
351stroker's Avatar
Blue loctite might help.
Old 07-03-2013, 07:58 PM   #8
Yes they should be loctited in. Also dont forget if u remove the drive shaft to mark it so it goes back on the same way..
88stanger is offline   Reply With Quote
Old 07-04-2013, 10:04 AM   #9
wc3john's Avatar
Never removed it, the shop just impacted them back in.
On another note, I never realized how many spelling and grammar errors I was having on the Iphone app. Jesus, I looks like I'm still in the first grade.
Old 07-04-2013, 10:13 AM   #10
DustyStang306's Avatar
If you can I would lift the back up get under there an take them out loctite them an throw them back in you always use loctite or you'll be under there in a few weeks to tighten them back up...iv done that before trust me loctite is your best friend when working on drive train stuff
DustyStang306 is offline   Reply With Quote
Old 07-04-2013, 10:18 AM   #11
wc3john's Avatar
Well I don't have a lift and the best spot I can work on the car is on the side of the street lol. When the shop owner gets back from vacation, i'll definitely have them put some locktite on.
Old 07-04-2013, 10:28 AM   #12
Lol iv done lots on the side of streets hahaha and out side in the snow an mud.... You name it iv had to lay in it haha but if I where you I'd do it my self it's easy an cheap an if your cars not lowered then you maybe able to do it with out lifting the back up or put two tires on the side walk an the other two on the street an you could have in done 10 mins or less and it won't even coast 10 bucks lol
Old 07-04-2013, 10:32 AM   #13
wc3john's Avatar
Oh its lowered allright lol. It has the eibach 2'' drop or something like that, plus my exhaust is kinda close to the driveshaft.
Old 07-04-2013, 10:41 AM   #14
Lol I'm just to cheap to pay a shop to do something I could do if I had a shop put my new motor an fuel system I would have been like 1500 to 2500 just for them to put it in lol I would rather save it for some umi lowers and t box reinforcements lol and still have a little money left over for paint haha
Old 07-04-2013, 02:44 PM   #15
I have a link some where with build your own tbox reinforcments. If you want I can dig it up later when I get a chance?
Old 07-04-2013, 02:57 PM   #16
Sure man that would be great just pm it to me if you can find it Save me even more money I'm always good with that haha
Old 07-04-2013, 03:02 PM   #17
Ok. Its on my pc. If I forget to send it by tomorrow shoot ne a reminder.
Old 07-04-2013, 03:50 PM   #18
Iight sounds good thanks man
Old 07-10-2013, 06:07 AM   #19
wc3john's Avatar
He'll I could use it. Post it on here lol
Old 07-11-2013, 07:53 AM   #20
351stroker's Avatar
Ya me too. I was just about to buy a kit.
Old 07-11-2013, 10:37 AM   #21
http://www.moddedmustangs.com/forums...build-how.html here it is boys
Old 07-11-2013, 02:09 PM   #22
351stroker's Avatar
Sweet thanks. Time to aquire some steel and get to work.
Old 07-11-2013, 03:15 PM   #23
Ye man I'm making my here soon I'll let you know how it goes
03:29 PM
