95 302 problems - Mustang Evolution
Old 07-07-2013, 12:25 PM   #1
sean5.0's Avatar
95 302 problems
Friend has a 95 GT with a 302. It shows to run past normal on the temp gauge and pings almost all of the time. All of the cooling system has been replaced and it is even running with no thermostat and still pings. It has also had the distributor, crank sensor replaced as well. A Ford dealer has even looked at it and hasn't come up with what the problem might be. Any help would be appreciated.
sean5.0 is offline   Reply With Quote
Old 07-07-2013, 12:42 PM   #2
McNassty's Avatar
Why is it running without a thermostat when it has a new cooling system?
McNassty is offline   Reply With Quote
Old 07-07-2013, 12:56 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
Timing needs adjusted..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-07-2013, 01:23 PM   #4
sean5.0's Avatar
It's still pinging and running hotter than it should on the gauge. It has a new radiator water pump and has been flushed and has had three different thermostats in it. Removing was a rest to see if it cooled down which it did but not enough to elongate the ping
---------- Post added at 02:23 PM ---------- Previous post was at 02:21 PM ----------
Ting has been set and verified three times since the new distributor was installed
Old 07-07-2013, 01:41 PM   #5
86 muscle's Avatar
Put a thermostat in it. Check the heater core, make it isnt plugged. Are we sure its a ping and not a knock? Valve train could be loose, you could be running bad gas as well. I also think you need to check timing. Set it at factory spec for while you are doing this. Make sure you also have the proper firing order.
86 muscle is offline   Reply With Quote
Old 07-07-2013, 01:44 PM   #6
sean5.0's Avatar
We've done all that. And yes it's a ping
Old 07-07-2013, 01:50 PM   #7
Robbiemustang96's Avatar
is your cooling fan turning on?!
Robbiemustang96 is offline   Reply With Quote
Old 07-07-2013, 01:54 PM   #8
sean5.0's Avatar
Yea
Old 07-07-2013, 01:59 PM   #9
are you sure none of the radiator hoses are clogged?
Old 07-07-2013, 02:01 PM   #10
Are there any indications that it may have a blown head gasket?
Old 07-07-2013, 02:21 PM   #11
351stroker's Avatar
Blown head gasket could cause ping cause its wetting down the cylinder. Smell exhaust see if it smells sweet or one side showing white smoke.
351stroker is offline   Reply With Quote
Old 07-07-2013, 04:22 PM   #12
What you describe sounds very much like a blown HG. Is your oil milky looking or anything? Definitely check the exhaust like was already mentioned. Are you sure your belt is routed properly around the water pump pulley and that you have the correct rotation water pump?
Old 07-08-2013, 07:07 AM   #13
bnoist114's Avatar
Its probably the HG, but bypass your heater core to make sure that's not it, an check your gauge too. The ping could be a different problem an not related to your cooling system
bnoist114 is offline   Reply With Quote
Old 07-08-2013, 10:31 AM   #14
Jar72's Avatar
Have the same car and had similar problem. I used a radiator coolant flush twice nasty stuff came out of the block. That helped a lot. The ping I had was fixed by timing adjust and running 91 octane. Only pings now under hard acceleration if the A/C is on. You can all use a mechanics stethascope to find the location or area of the ping. Wouldn't trust the temp guage. My indicator bar actually fell off
JMF
Jar72 is offline   Reply With Quote
Old 07-08-2013, 01:04 PM   #15
Something is still wrong with it if it pings at all.
Old 07-08-2013, 02:02 PM   #16
Jar72's Avatar
Just found out a minute ago I need bigger Injectors and Maf upgrade
JMF
Old 07-08-2013, 02:52 PM   #17
sean5.0's Avatar
That might help we'll try it
Old 07-08-2013, 04:23 PM   #18
What is leading you to that conclusion? Because if you don't have anything major done to your car the stock 19s are fine. You might need NEW injectors after all this time though. You'd be amazed at what they'll look like at this age. When I pulled the original injectors out of my 95 back in 2007 they were literally falling apart.
Old 07-08-2013, 04:32 PM   #19
Jar72's Avatar
Scotty can you possibly carry this over to a post I made its listed as. Injectors? Or look it up under my profile. Thanks.
JMF
06:48 PM
