injectors? - Mustang Evolution
Old 07-08-2013, 10:48 AM   #1
Jar72's Avatar
injectors?
I looked around in here and didn't find the answer to this..
If I'm running gt40 intake and heads set up should I change to the 24# injectors from the 19# stock?
JMF
Jar72 is offline   Reply With Quote
Old 07-08-2013, 12:13 PM   #2
DustyStang306's Avatar
Yea I would say you should your probably running a little lean at high rpm with them 19s
DustyStang306 is offline   Reply With Quote
Old 07-08-2013, 12:17 PM   #3
McNassty's Avatar
Yes, you should change them and get a MAF that is calibrated for 24lb. Injectors
McNassty is offline   Reply With Quote
Old 07-08-2013, 12:43 PM   #4
Jar72's Avatar
That's what I thought. Any suggestions on the Maf. can I pull one from a junkyard ??? That's the moto for this car. Trying to use as many cheap junkyard parts as possible to prove a point to a buddy who's spending mega bucks on parts so far I'm in the lead.
JMF
Old 07-08-2013, 01:11 PM   #5
McNassty's Avatar
If you can find a '95 cobra MAF they are tuned for 24lb. Injectors might be '94 too I can't remember what years came with 24lb. Injectors
Old 07-08-2013, 01:20 PM   #6
WhiteCobra94's Avatar
FYI I had this prob, I did a HCI swap and my 24lb injectors were maxing out at 4800 RPMs I had to bump up to 30lb
Old 07-08-2013, 06:29 PM   #7
I found this awhile back when I had my injector issue, hope it helps!
02:27 AM
