Advanceing timeing? Good idea? - Mustang Evolution
Old 07-09-2013, 06:08 AM   #1
94gtconvert's Avatar
How much hp could I gain and how much do I advance it? Also do I have to always run premium fuel because my dad borrows my car sometimes and puts 87 in lol.
94gtconvert is offline   Reply With Quote
Old 07-09-2013, 08:57 AM   #2
14 degrees timing is good for 93 octane. I ran my 95 for years this way and it did pick up some power.
Old 07-09-2013, 09:14 AM   #3
harryb5a4's Avatar
Region: West Virgina
I agree same here I have my 88 running at 14 and it seems to love it
harryb5a4 is offline   Reply With Quote
Old 07-09-2013, 11:52 AM   #4
How much hp do u think I will get?
Old 07-09-2013, 02:39 PM   #5
I got a good SOTP kick but my 95 was a Cobra, you might not feel that much of a difference but it will make a little more power and have better off idle characteristics.
Old 07-09-2013, 03:03 PM   #6
Minus2380's Avatar
I advanced my timing on my 95 GT to 12 and it started pinging. Then I retarded it back to 10 and now I push the gas and doesn't have power. So just a Lil heads up that's all
Minus2380 is offline   Reply With Quote
Old 07-09-2013, 03:10 PM   #7
Were you running 93 octane?
Old 07-09-2013, 06:52 PM   #8
Minus2380's Avatar
87-91 octane. Colorado it's rare to find 93 octane. I can't pinpoint what's going on
Old 07-09-2013, 07:33 PM   #9
What altitude are you at?
Old 07-09-2013, 08:58 PM   #10
Well if you started advancing the timing running 87 octane... yeah it'll start to ping... especially higher up in altitude.
Old 07-10-2013, 12:45 AM   #11
FortyBrandon's Avatar
Not to steal your thread from underneath you but can someone explain what advance timing is and how you change it? I like the thought of more hp and I have a 99 cobra that uses only 93 octane so does that mean its set to 14 already or can my sct tuner change it????
FortyBrandon is offline   Reply With Quote
Old 07-10-2013, 03:15 AM   #12
93slowstang's Avatar
You would have to have it tuned through your sct to change timing.
Old 07-10-2013, 07:55 AM   #13
This thread is about cars with a distributor where you can just use a timing light and turn the distributor to advance/****** timing. On a modular it all has to be done electronically.
Old 07-10-2013, 08:24 AM   #14
Does the engine run hotter with advanced timeing?
Old 07-10-2013, 08:40 AM   #15
Steady at 180-200 on the cobra with a 180 tstat and fan set to come on at 180.
Old 07-10-2013, 09:15 AM   #16
Minus2380's Avatar
Yea I backed it down to 0 and it stopped. I think I'll get it professionally tuned to avoid the headache lol
Old 07-10-2013, 10:26 AM   #17
FutileTerror9's Avatar
Whoa, it should be at 10 from factory, man. Not 0.
FutileTerror9 is offline   Reply With Quote
Old 07-10-2013, 01:23 PM   #18
What condition is your balancer in. Its possible that the timing ring has slipped over time.
Old 07-10-2013, 08:19 PM   #19
No wonder it runs like *** you have it 10 degrees retarded...
Beat me to it.
Old 07-10-2013, 09:13 PM   #20
Minus2380's Avatar
When I do set it to 10 deg it will ping then as well.
Old 07-11-2013, 06:06 AM   #21
Are you sure you are setting it properly?
Old 07-11-2013, 06:15 AM   #22
Minus2380's Avatar
Yea. The guy I got the car from said he just replace the distributor and when you do that don't you have to ou the engine at TDC?
Old 07-11-2013, 07:51 AM   #23
351stroker's Avatar
Hmm. Sounds like u didn't set it right. It should be normally at 10 degrees not zero.
---------- Post added at 07:51 AM ---------- Previous post was at 07:48 AM ----------
There's a little plug in chip inline with the wiring harness running to the distributor. U need to pull that out before setting the timing. It will make the car run kinda crappy but that's what u need to set the timing. There u can try 12 & 14 degree timing. Once it's set THEN plug the chip back in and go for a burn. Have fun!!
351stroker is offline   Reply With Quote
Old 07-11-2013, 04:41 PM   #24
Minus2380's Avatar
Ill give it a shot again. Thanks
Old 07-11-2013, 05:00 PM   #25
67mustang97's Avatar
Region: Vermont
At 12 what octane should I run?
Old 07-11-2013, 05:30 PM   #26
If you are advancing the timing at all just run 93 octane or whatever is highest around you. Its like what 20 cents more per gallon?
10:02 PM
