Weeping lower head studs - Mustang Evolution
Old 07-09-2013, 11:37 AM   #1
Durnstang's Avatar
Just put my 5.0 back together and I have one stud leaking some coolant has anyone ever pulled one at at time and resealed? Don't want to yank my heads
Durnstang is offline   Reply With Quote
Old 07-09-2013, 12:27 PM   #2
Yeeesh. I have never done that. In your case, I think that I would also consider giving it a try depending which bolt that it is. If it doesn't work or leaks worse after you're done, the head will need to come off anyway. On second thought, knowing me, Id pull that head and fix it right...
Old 07-09-2013, 12:36 PM   #3
Durnstang's Avatar
Ya I've been staring at it. It's at the back I could have it out in 5min drain coolant seal it and done i think I'm gonna try what's the worst that could happen? It still leaks haha. What could go wrong? Thanks
Old 07-09-2013, 03:14 PM   #4
Did you put the ARP thread sealer on the studs that go into the water passages?
Old 07-09-2013, 03:38 PM   #5
Durnstang's Avatar
Permatex
Old 07-09-2013, 03:59 PM   #6
Hmmm, did you use ARP studs? Torqued to 80/80/80? Felpro 9333 gaskets? I'd honestly pull the head and redo it. Best case is you fix it, worst case is you've got a warped head...
Old 07-09-2013, 07:44 PM   #7
Durnstang's Avatar
No uppers 70 lowers 60 as per arp calls for on 7/16 studs and coolant coming up from the water jacket probably just means I didn't do a good job sealing it or theres an issue with the threads and heads are fresh from machine shop I just chased treads and resealed the one stud ill let you know if it worked thanks
Old 07-09-2013, 08:56 PM   #8
Three equal steps of 80 ft lbs
Direct link to the ARP 7/16 head stud kit instructions on the ARP website. These are the torque values I used when I did my motor and had 0 issues.
Old 07-11-2013, 08:35 PM   #9
Durnstang's Avatar
Good to go. It worked!
Old 07-11-2013, 08:45 PM   #10
Glad to hear its sorted out. Did you torque them all to 80 or just chase and re-torque to what you had? They'll most likely be fine at 60, they used to be spec'd for that, not sure why ARP changed the specs but w/e.
Old 07-11-2013, 08:52 PM   #11
Haha. Thats AWESOME!!!!! Don't you love it when a plan comes together...
Old 07-12-2013, 03:47 AM   #12
Durnstang's Avatar
Ya just the one check the rest all good left at 70 and 60 dasilva racing also suggested this spec or 80 and 70 but they said at at point you're just stretching the bolts. They only clamp so much. Thanks for the input👍
03:04 AM
