Has anyone every tried this? - Mustang Evolution
Old 07-10-2013, 08:13 PM   #1
WhiteCobra94's Avatar
Has anyone ever used a coolant additive? With these 90 degree days and high humidity my car is running hotter (not over heating) and I was looking on Anderson's website and seen this. Says helps the coolant cool up to 20 degrees on average ! For $15 is it worth a try?
http://www.andersonfordmotorsport.co...-Additive.html
Old 07-10-2013, 08:43 PM   #2
If you want to see if a coolant additive helps you out just go to your local box store and pick up a $10 bottle of Water Wetter.
Old 07-11-2013, 03:50 AM   #3
Durnstang's Avatar
Agreed just go get water wetter. I run it with distiller water.
Durnstang is offline   Reply With Quote
Old 07-11-2013, 04:15 AM   #4
Ok I'll give it a try
Old 07-11-2013, 05:00 AM   #5
What stores carry it ? Like autozone ?
Old 07-11-2013, 05:07 AM   #6
Durnstang's Avatar
Ya any big auto store or local performance shop will have it
Old 07-12-2013, 08:53 AM   #7
This is where my temp is sitting .
Normally it sits on the "R" in normal
Old 07-12-2013, 09:16 AM   #8
Well it is getting hot as balls out. What tstat do you have in there and is your fan coming on when it should? How old is the radiator? Also who did the white faces? You sure that needle is back on properly?
Honestly that stock gauge is called an "idiot gauge" for a reason. I HIGHLY suggest you get an aftermarket mechanical gauge for water. And oil pressure.
Old 07-12-2013, 09:30 AM   #9
The white face was done 10 years ago, the radiator is 11 months old , I do have new oil pressure , voltage, temp , and fuel pressure gauges , I need to get sending units
Old 07-12-2013, 10:01 AM   #10
And I have a 180 degree stat
11:50 PM
