Wheel question! - Mustang Evolution
Old 07-14-2013, 07:20 PM   #1
Four Eyes's Avatar
Wheel question!
Can I run a 17x9 in front and a 17x10 in the rear of my 86 GT? I won't have any rub in the *** end?
1986 GT with the typical poor boy mods. 3.73s, Hurst short throw, King Cobra Clutch with aluminum quadrant, lowered two inches on Eibach springs, Hopefully adding some heads and a decent intake soon!
Four Eyes is offline   Reply With Quote
Old 07-15-2013, 01:54 PM   #2
jsampson02's Avatar
Does the 86 come with the 2 shocks on each side in the rear? If so, i believe the lateral shocks have to be removed to fit the wheel, leaving just the single vertical shock.
jsampson02 is offline   Reply With Quote
Old 07-15-2013, 02:04 PM   #3
2300turboford's Avatar
Yes it comes with 1 regular shock and one quad shock on each side and I ran 17x9 and 17x10 on my fox but I had to roll the quarter panels
---------- Post added at 04:04 PM ---------- Previous post was at 04:03 PM ----------
And I had my quad shocks to you can flip em around and get alittle more clearance
Old 07-15-2013, 05:06 PM   #4
Four Eyes's Avatar
Awesome that's what I wanted to know!
Old 07-15-2013, 07:29 PM   #5
Plenty of room, might have to flip the quads or remove them but you can get 10.5s back there without too much of a problem so 10s are fine.
Old 07-15-2013, 10:06 PM   #6
havhammer's Avatar
On my 93 I run 18×10's and all I had to do was flip the quad shock.
havhammer is offline   Reply With Quote
Old 07-16-2013, 01:07 AM   #7
Four Eyes's Avatar
Yes but 86s have a smaller wheel arch.
Old 07-16-2013, 07:11 AM   #8
Out front they do, out back should be the same IIRC. Front fenders changed over in 1991 to wider.
Old 07-16-2013, 01:16 PM   #9
Four Eyes's Avatar
I thought it was 1990?
Old 07-16-2013, 01:22 PM   #10
I'm pretty sure its 1991... I could be wrong...
Old 07-16-2013, 02:10 PM   #11
Four Eyes's Avatar
You're probably right. You've most likely been around mustangs longer than I've been alive.. Lol.
Old 07-16-2013, 05:49 PM   #12
lx92coupe's Avatar
It was when the pony wheels came out
2013 GT Roush Stage1 TVS
lx92coupe is offline   Reply With Quote
Old 07-16-2013, 09:42 PM   #13
93slowstang's Avatar
Which was in 90, they widened the arches in 91.
Old 07-16-2013, 09:45 PM   #14
You'll likely have to remove the quads or flip them. It depends mainly on the offset. Depending on tire brand and size you may also have to roll the fenders.
Old 07-16-2013, 09:57 PM   #15
Four Eyes's Avatar
When you say roll the fenders, you mean the inner lip right? The spot weld crease?
Old 07-16-2013, 10:03 PM   #16
lx92coupe's Avatar
It might have been 1990 but it was the 91 model year that pony wheels came out You can get a 14 in 2013
Reference here- http://www.musclemustangfastfords.co...s/viewall.html
Old 07-16-2013, 10:03 PM   #17
No he means the outer fenders... I'd put the car on jackstands and put the rims on the back for some test fitting and see what you want to go with. Also remember that some brands run wider or narrower than others of the same size. Like a BFG 315 is going to be SUPER wider than a Nitto 315 will.
Old 07-16-2013, 10:08 PM   #18
lx92coupe's Avatar
Here is a good article about fitment on fox
http://www.mylrs.com/blogs/lrs/archi...ire-guide.aspx
Old 07-17-2013, 10:16 AM   #19
Four Eyes's Avatar
Decent article. Thanks!
Apparently I can't run a 17x9 in the front of my 86 gt due to strut clearance.
Old 07-17-2013, 12:22 PM   #20
351stroker's Avatar
I got a set of 17x9's from The Mustang shop in Calgary and they fit no problem. I even have an 1-1/2 lowering springs. Didn't have to roll the fenders or nothing. Buddy has 16x8 on his car, same year just rear wheel disc brake and his fenders cut up the tires so bad I had to replace one on the highway once. His fenders definitely need to be rolled.
351stroker is offline   Reply With Quote
Old 07-17-2013, 12:25 PM   #21
351stroker's Avatar
Old 07-17-2013, 12:27 PM   #22
351stroker's Avatar
First pic is the rear wheel well with a 17x9 with a 235 45zr17 , second pic same tire size front wheel well. Car is lowered 1-1/2" as well.
Old 07-17-2013, 12:30 PM   #23
Four Eyes's Avatar
Mine is lowered 2 inches, and I'm looking to go lower on coilovers.
Old 07-17-2013, 12:46 PM   #24
351stroker's Avatar
Wow. That is low. Show me when it's done.
Old 07-19-2013, 10:42 AM   #25
Durnstang's Avatar
My friends 89 he has 10 inch saleens with 275 50s ET streets and his inner fender lip had to be rolled or he would thrashed his new rubber
---------- Post added at 11:42 AM ---------- Previous post was at 11:41 AM ----------
Yes roll or trim
Durnstang is offline   Reply With Quote
Old 07-19-2013, 10:48 AM   #26
Durnstang's Avatar
Offset plays a big part don't forget
08:53 AM
