1990 5.0 engine - Mustang Evolution
Old 07-15-2013, 09:49 AM   #1
1990's Avatar
1990 5.0 engine
Why does my 5.0 hesitate when I punch the gas... Mostly from a rolling start. Is it because it is older? How can I fix it?
1990 is offline   Reply With Quote
Old 07-15-2013, 01:06 PM   #2
WhiteCobra94's Avatar
Your air/fuel could be off , or bad TPS
Old 07-15-2013, 01:08 PM   #3
1990's Avatar
Easy to fix
---------- Post added at 02:08 PM ---------- Previous post was at 02:08 PM ----------
Old 07-15-2013, 01:45 PM   #4
Originally Posted by 1990 View Post
Easy to fix
I'd bring it to your local speed shop and have them do it
Old 07-15-2013, 04:56 PM   #5
foxbox's Avatar
It could be many things man. First try a tune up ( plugs, wires, all filters,.cap and rotor, maybe coil). Then check timing. I would try that out before replacing sensors...that can get expensive fast. Do you have any mods? How bad of a stall are we talking here?
foxbox is offline   Reply With Quote
Old 07-15-2013, 04:59 PM   #6
1990's Avatar
Just about a second
Old 07-15-2013, 10:09 PM   #7
havhammer's Avatar
First make sure your mass air wire is clean. No fuzz or oily residue from a k&n filter. They (forgot who, gray can. I think crc) make a spray now to clean the sensor/wire. It works well and won't harm it.
havhammer is offline   Reply With Quote
Old 07-15-2013, 10:14 PM   #8
1990's Avatar
I've already looked at that it looks brand new
Old 07-15-2013, 10:25 PM   #9
havhammer's Avatar
Then start with the basics; tune up, timing, fuel filter, air filter, cap, rotor, dirty injectors...
Old 07-16-2013, 01:25 PM   #10
If you haven't done a full tune up, do a full tune up. Assuming you have the stock heads:
-Autolite 25 Spark Plugs
-FRPP wires
-FUEL FILTER
-Oil
-Trans and diff fluids
-Clean MAF sensor
-Air filter
-Cap/Rotor
-If you have access to 93 octane fill up with that and set timing to 14 degrees advanced
06:16 PM
