91 GT with a C4 trans - Mustang Evolution
Old 07-21-2013, 05:28 PM   #1
jsampson02's Avatar
I bought this car for a project/resto, it was pretty banged up. After finishing all the visual/drivability stuff, now its upgrading. The owner swapped the AOD to a C4 trans, but the shift linkage dosent match correctly, even the mounting was half a$$ed for that matter. Since it's a 3 speed it shifts out of 1st fairly quickly losing its "off the line" power, and the way the linkage is I can't get into low manually, only 2nd. If I adjust the linkage to get me low, then I lose park. Anyone heard of an AOD to a c4/c5 swap that didnt mess up the gear travel?
jsampson02 is offline   Reply With Quote
Old 07-21-2013, 08:55 PM   #2
Four Eyes's Avatar
Sounds weird to me.
1986 GT with the typical poor boy mods. 3.73s, Hurst short throw, King Cobra Clutch with aluminum quadrant, lowered two inches on Eibach springs, Hopefully adding some heads and a decent intake soon!
Four Eyes is offline   Reply With Quote
Old 07-21-2013, 09:01 PM   #3
jsampson02's Avatar
My father told me I can get an aftermarket shift modulator for it, that has a set screw that can be adjusted to bump out all the shift points. But it just sucks not have manual low. We had it on the lift and disconnected the linkage and moved the shift lever my hand, and it hits every gear. But you can see that there just isnt enough cable travel to get the job done.
» Members Mustangs
Big Yellow
Rikaj
G.L.
joe89
Add your Mustang
11:36 PM
