I cant find an answer, T5 v8 question. - Mustang Evolution
Old 07-21-2013, 09:53 PM   #1
BloodRedStang's Avatar
Ok, I've searched high and low for an answer to this, every time I think I have found the answer I get halfway through the replies and there's contradicting info..
So here goes.
Will a 1995 t5 out of a v6 bolt up to a 1994 gt without having to change the input shaft?
I know the bellhousings are different, that's not an issue.. I also know that the v6 trannys are slightly weaker..
I have a 1995 v6 "parts car" right now that has everything I need to do a 5 speed conversion in a 94-95 gt, the pedals, any crossmembers or bracketry, interior...etc.
The trans that's in my car has been beefed up, I have no doubts it will handle the power the gt in question is putting out.. but I seriously cannot get a definitive answer.. will it work with the proper bell, and stock v6 input shaft? If so, will I need a v6 pilot bearing or anything specific like that?
Please please please, someone out there tell me! Lol
BloodRedStang is offline   Reply With Quote
Old 07-21-2013, 09:58 PM   #2
Black on Boss's Avatar
So here goes.
Wish I could help. Good luck.
Old 07-21-2013, 10:00 PM   #3
Ubnbit's Avatar
Find scottydsntknow or cliffyk. There are some other guys that will help too.
Old 07-21-2013, 10:04 PM   #4
I talked to scottydsntknow the other day about some automatic questions. Dude knows his stuff
Old 07-21-2013, 10:06 PM   #5
Ubnbit's Avatar
He needs to change his name to Scottyknows lol. I see him post and ill say, "see, Scotty knows" lol. He's one of the best. We have several guys that know what they are talkin about.
Old 07-21-2013, 10:09 PM   #6
Indeed man. I was wondering about some stuff with an auto trans because I seriously know like nothing about autos.. I really on mess with engines or standard trans.. and this dude commented with like 4 paragraphs of knowledge.. I learned a lot from that one post
Old 07-21-2013, 10:11 PM   #7
2300turboford's Avatar
You will have to change the input shaft and I'm pretty sure they are 40lbs of tourque weaker than a v8 t5
Old 07-21-2013, 10:13 PM   #8
How hard is changing the input shaft, and is that something that can be bought from say..summit?
The trans I have has been beefed up, I don't doubt it handling the power.. I just don't know if I have to change the input if its worth the extra work than just getting a 302 t5 from a fox or 94-95..
Old 07-21-2013, 10:17 PM   #9
I can't give you the exact steps but the t5 in my 2.3t (same as a v6 tranny) held up to quit a bit of abuse just don't power shift and you should be fine
Old 07-21-2013, 10:24 PM   #10
The older 2.3 t5s and 94-95 input shafts are different. I think there's like 3/4ths inch difference in the 2.
I've heard that the 94-95 v6 and v8 t5 input shafts are the same but the bellhousing starter locations are different.. I've also heard there's a few mm difference in the input shaft.. somebody told me that the v6 trans and bellhousing will work given I use a different flywheel to accommodate the starter location.. idk lol
If I can use this t5, with the gt bell and clutch kit..that's what ill do because its damn near impossible to get a 94-95 t5 around here for under 700 bucks
Old 07-22-2013, 02:19 AM   #11
Ok, got verification from multiple sources.
94-95 v6 and v8 transmissions are bolt in interchangeable. The bellhousings are different.
Older or newer trans require mods.
If you use a t5 from a fox, 4 or 8 cylinder, you need the bellhousing from the same year group.
A shout out to scottydsntknow for verifying!
Glad this lingering question in my mind is answered.. I think what confused me was the different year changes
Old 07-22-2013, 05:27 AM   #12
Ya the T-5 from 94-98 V6 cars is a direct bolt up. 99-04s need a mod to the tailshaft for the speedo but are stronger. All but the most built T-5s are disasters waiting to happen IMO although they do shift buttery smooth...
Old 07-22-2013, 05:50 AM   #13
^ knows his stuff huh lol
Old 07-22-2013, 06:06 AM   #14
Old 07-22-2013, 07:30 AM   #15
Lol. I was saying you know your sh1t
12:12 PM
