Torque converter - Mustang Evolution
Old 07-24-2013, 11:42 AM   #1
fordtough1991's Avatar
Torque converter
I don't know much about automatic transmissions can somone please explain how a stall of a torque converter works?
fordtough1991 is offline   Reply With Quote
Old 07-24-2013, 11:58 AM   #2
It basically works like a clutch for autos... I'm bad at explaining this...
Say you have a 2800 rpm stall converter. At idle it'll be fully unlocked. Once you hit the gas it'll allow less and less slippage up to 2800rpm, sort of like letting the clutch out to that point. After that it is fully locked up just like the clutch is fully engaged. A big plus to a higher stall converter is the ability to come off the stall under a full load/boost from a standstill.
Then you have torque multiplication... under initial acceleration most torque/stall converters have a multiplier of 2.5:1 so you can definitely understand why most serious drag cars are automatics. You come out of the hole MUCH harder not to mention the auto will never miss a shift...
At any rate, that is the basics of a stall converter... very basic...
Old 07-24-2013, 12:04 PM   #3
Ubnbit's Avatar
The only thing I saw was Scotty say, "I'm not very good at explaining this." Lol. Then, I had to read it. Of course as always, he knocked if out! Scotty, where did u get all of ur knowledge?
Old 07-24-2013, 12:14 PM   #4
Years of wrenching on these stupid things...
Old 07-24-2013, 12:16 PM   #5
Ubnbit's Avatar
Lmao. No training or schooling? I have worked on something since I was old enough to and will never have that skill brother.
Old 07-24-2013, 12:36 PM   #6
I'm a mechanic as my primary job but not on cars, maybe that helps?
Old 07-24-2013, 02:39 PM   #7
Thanks man that explains it perfect I've been trying to figure this out for a lil while now!
Old 07-27-2013, 10:03 AM   #8
WhiteCobra94's Avatar
I went through all this last year when I was looking for a high stall torque converter and I was told buy the techs at summit racing when your looking for a T/C you want to go 300 to 500 RPM's higher in the stall then what your baseline power for your Cam is: example my cam's baseline is 2,200 RPMs and I went with a 2800-3000 stall torque converter !
11:30 PM
