How does an 89 5.0 handle spray? - Mustang Evolution
Old 07-26-2013, 12:13 AM   #1
Luna1994's Avatar
Region: Utah
So my friend has an 89 with 89 k miles on it...how does the stock block handle a small spray like 50? 75? 100?
Luna1994 is offline   Reply With Quote
Old 07-26-2013, 05:56 AM   #2
Dion11197's Avatar
These motors typically speaking do fine. However it all depends on how worn his motor is. If the car gets beat on regularly then I would say the smaller the better. If it is relatively taken care of, the 100 shot shouldn't be an issue. I would highly recommend a wet kit, that way you have the extra fuel you need and are less likely to cause a lean situation and grenade the motor.
Dion11197 is offline   Reply With Quote
Old 07-26-2013, 08:23 AM   #3
wc3john's Avatar
Do a wet kit as said before but with an adjustable fuel regulator just in case. With le nitrous, you can never have too much fuel for that just in case...
At this get together I go to ALOT, there's a 90 gt that has nothing but a regulator, 24 lb injectors and maf and a 150 wet shot. Spanks the **** out of every gt40 swapped 5.0 that comes along.
---------- Post added at 09:23 AM ---------- Previous post was at 09:22 AM ----------
Just be sure to back the timing off a few degrees
I chug syrup for money...
wc3john is offline   Reply With Quote
01:29 AM
