Throw out bearing - Mustang Evolution
Old 07-27-2013, 10:08 AM   #1
FoxBodyRob's Avatar
Throw out bearing
How can I tell if my throw out bearing should be replaced? The bearing spins freely with minimal noise or grinding. But my engine and tranny are already separated, so should I just replace it anyway since they aren't all that expensive? I'd appreciate your feedback thanks!
FoxBodyRob is offline   Reply With Quote
Old 07-27-2013, 10:46 AM   #2
FortyBrandon's Avatar
U push clutch in and it whines. U release clutch and its quiet
FortyBrandon is offline   Reply With Quote
Old 07-27-2013, 10:51 AM   #3
tc x 4's Avatar
Since it's already apart, it's a no brainer, replace it and the clutch.
Old 07-27-2013, 11:29 AM   #4
FoxBodyRob's Avatar
Yeah that's pretty much what I thought. Thanks
Old 07-27-2013, 11:57 PM   #5
Billymich's Avatar
Yes, replace it also the pilot bearing!
Old 07-28-2013, 05:17 PM   #6
+1 million. TOB/Pilot bearing should be done whenever the trans separates from the engine. Clutch is a good idea too unless you know it has low miles. If its a 20k mile good clutch, for example, no reason to change it.
Old 07-29-2013, 01:54 PM   #7
FoxBodyRob's Avatar
I agree. I'm just going to go ahead and order a new clutch kit (clutch, pressure plate, tob, & pilot + alignment tool) doesn't make sense not to do it since its already apart.
Old 07-29-2013, 02:14 PM   #8
Billymich's Avatar
Might be a good time to change tran fluid if you have the money and are so inclined. Also if your rear main seal is having issues now is the time
Old 07-30-2013, 07:23 AM   #9
bnoist114's Avatar
Always change your rear main seal, and pilot/throw out bearings whenever u have trans out. They dont cost alot, and its good peace of mind. I made mistake before and didnt change rear main when i changed clutch, an 2 weeks later i was losing oil from there an had to pull trans again for a seal. So always change em anytime teans is out
bnoist114 is offline   Reply With Quote
07:48 AM
