87 trans aod stalls engine in drive please help - Mustang Evolution
Old 07-28-2013, 09:00 PM   #1
Hey guys I'm new here and just got my second mustang. 1987 LX 5.0 auto aod trans. Bought it a week ago with the trans out of the car. Guy said it would die in all gears. So talking with some tranny shop advise was put a new converter in it. So I bought a new converter and installed the trans today. New fluid and filter. On jacks I try starting it in park and dies. Start it in neutral and it runs but idle is rough but wheels spin. Put it in park, drive, or reverse and tires spin and dies when brakes applied. Not sure if its in the tranny gears or valve body. Please help. Thanks in advance.
87302LX is offline   Reply With Quote
Old 07-28-2013, 10:09 PM   #2
Billymich's Avatar
Clean your IAC
Old 07-28-2013, 10:33 PM   #3
Would that just help the idle or does it also effect the transmission issue as well?
Old 07-28-2013, 10:35 PM   #4
Billymich's Avatar
Idle, but if your car won't idle in gear it could be that, plus these cars are really old and things get dirty
Old 07-29-2013, 04:40 PM   #5
Cleaned the iac and still have problem. I even disconnected it and no change. I'm pretty sure it's in the transmission just have to figure out what part of the tranny. Still open to suggestions.
Old 07-29-2013, 04:51 PM   #6
Billymich's Avatar
I don't know, I'm a manual guy
Old 07-29-2013, 05:14 PM   #7
Ya me to stupid auto's.
Old 07-29-2013, 05:18 PM   #8
Gibby's Avatar
Could still be the iac... I pretty sure there is a diaphram in there that plugs the hole in the intake. Maybe pull the cover off and stick your finger in the hole while its running to double check
Gibby is offline   Reply With Quote
Old 07-29-2013, 05:20 PM   #9
When I had it off the little plunger inside would move back and forth pretty easily. Is that right?
Old 07-29-2013, 05:31 PM   #10
Billymich's Avatar
Yes, also make sure its clean of carbon buildup
Old 07-29-2013, 05:45 PM   #11
Ok, I wonder if the tv cable is way out of adjustment? Does that control the pressure in the transmission ? Maybe keeping it always engaged when its started and pressures are to high...
Old 07-29-2013, 07:23 PM   #12
Billymich's Avatar
TV cable?
---------- Post added at 08:23 PM ---------- Previous post was at 08:23 PM ----------
Throttle cable??
09:24 AM
