Head gaskets are bad. - Mustang Evolution
Old 08-01-2013, 08:45 PM   #1
Varasios's Avatar
Boiled up today on gauge , wasnt even hot outside. Recently got new tstat and flushed fluid.. Thought that may have been the issue but I have no pressure. I have idling pressure when holding revs up to 2500 - 3000 . Have oil coming up aswell in rad. Kick in the *** for an Aug 1st :/
Varasios is offline   Reply With Quote
Old 08-01-2013, 09:14 PM   #2
Billymich's Avatar
Yeah that sucks,I hope you didn't warp your heads or block like I did. Good luck let us know if you need any advice!
Old 08-02-2013, 08:31 AM   #3
Varasios's Avatar
Not even gonna repair.. Swap for a crate.. Done for the season or maybe even next season. Im officially depressed.
Old 08-02-2013, 11:28 AM   #4
351stroker's Avatar
Gaskets are cheap and its a fairly fast fix. I tore my top end apart in an hour and started cleaning parts and 3 hours later I was driving again. Driveway repair even.
---------- Post added at 11:28 AM ---------- Previous post was at 11:27 AM ----------
Gasket kit set me back $75 for head and intake gaskets.
351stroker is offline   Reply With Quote
Old 08-02-2013, 11:53 AM   #5
Billymich's Avatar
Yeah, but he may have warped heads. In any case what are you doing with that engine
Old 08-02-2013, 12:21 PM   #6
351stroker's Avatar
Not necessarily. I blew a head gasket and ran the car a little longer than I should have. Thought the worse. Pulled the entire motor and replaced it with a DSS 347. About A month ago I decided to pull the heads and see if they were ok to use on my truck. Straight edge said they were fine. So I'm porting and polishing them, Gonna have a sweet three angle done then send them for milling before I put them on the 150.
Old 08-02-2013, 04:45 PM   #7
DerekJohnScott's Avatar
That sucks but its a good excuse for a new motor!
DerekJohnScott is offline   Reply With Quote
Old 08-03-2013, 01:00 PM   #8
Varasios's Avatar
I know .. Gonna have to do some saving.. Just did ring pinion 3wks ago! Bummer. Was just starting to get the gears worn in a bit. Most likely going to just prepare for storage now. i'm from Canada, also I pay 580$ monthly in the summer for my Mustang and Dakota 'dd'.
Trying to plan out which engine I am going to grab. Im not looking to spend ridiculous money but on the other hand id like something decent.
I had a couple of questions for you guys.
The 306ci 340 hp motor , if I bought that and dropped in and installed all intake and ignition/fuel components would I have to get it tuned/dyno?
Is it better value to just get an engine fully assembled and a 'turn key' set up?
Old 08-03-2013, 02:44 PM   #9
351stroker's Avatar
Depends on what you want to spend, how much mechanical experience you have. But I don't see why not. If your gonna run a chip best is a dyno tune.
---------- Post added at 02:44 PM ---------- Previous post was at 02:43 PM ----------
And y so much for insurance! My 88 is only like $102 a month. Buddy pays $140 a month for his '11 GT.
Old 08-03-2013, 02:56 PM   #10
351stroker's Avatar
And my stroker build DSS level 10 block bored .030, rotating assembly, AFM cam so far $2800. I need a pile more parts and some I have laying around I estimate another $2500-$3000 in parts to go. So I am saving like $1500 or more doing it myself. That's $1500 more for a transmission I have. Hello T-56!
Old 08-04-2013, 01:29 PM   #11
Varasios's Avatar
I guess its so high because of my age (24) and i have collision on my 07 dodge dakota + 2 speeding tickets.
Where is the best place to order a engine from..summit racing? Ford racing?
I am from Brampton/Ontario/Canada
Whats a good example of a turn key engine forsale online.
I plan to strip all of the good parts off the old engine. Just installed a brand new msd pro billet dizzy and bbk cai, new maf .. Lots of decent stuff
Old 08-04-2013, 01:33 PM   #12
Varasios's Avatar
The guy put a t-56 in my car , came like that when i bought it
Old 08-04-2013, 04:57 PM   #13
351stroker's Avatar
Awe. So jealous. I would recommend one in Canada. Try themustangshop.ca or wmsracing.ca. Turn key ur prob looking $5-$7000
---------- Post added at 04:57 PM ---------- Previous post was at 04:57 PM ----------
Go with. 306 bullit
Old 08-05-2013, 11:03 AM   #14
Varasios's Avatar
Go with. 306 bullit
Having a hard time finding all the crate engines on themustangshop.ca
Old 08-05-2013, 11:10 AM   #15
351stroker's Avatar
Ya. I had to call myself last time. Maybe this will help.
03:08 PM
