GT40 install help! - Mustang Evolution
Old 08-03-2013, 07:43 PM   #1
Cblackstang's Avatar
GT40 install help!
So idk if i got In deeper than I should but ill give it a try..upon the installation I ran into a few issues broken bolt on fuel rail and now I need some help finding what vacuum hose go where
Here's the pics
Cblackstang is offline   Reply With Quote
Old 08-04-2013, 01:22 AM   #2
Billymich's Avatar
Just plug the ones you don't need if you have enough vac trees
Old 08-04-2013, 02:17 AM   #3
Billymich's Avatar
I'll trace out my vac lines in the morning and let you know.
Old 08-04-2013, 06:27 AM   #4
Alrite thanks!
Old 08-04-2013, 01:06 PM   #5
Billymich's Avatar
Name:   upper intake  vac.jpg
Red to red--->dark red---> PCV
green--> fuel pressure regulator
Blue--->goes to one of the vacuum solenoids on the passenger shock tower
Yellow---> charcoal canister
unmarked--> Vacuum tree source
this is based of my non GT40 HO upper which is different slightly. hope it helps, but may not be 100% accurate
Old 08-04-2013, 06:47 PM   #6
Are you sure blue and green arent switched? Blue seems like a pretty big Fitting for the regulator and green is smaller
Old 08-05-2013, 11:54 AM   #7
Billymich's Avatar
Nope, It was a best guess, my intake has different vac fittings
Old 08-05-2013, 12:07 PM   #8
Alrite thanks! Im pretty sure most of it was right now I just gotta put my TB on and start her up
07:49 PM
