Cooling fans? - Mustang Evolution
Old 08-05-2013, 11:06 AM   #1
WhiteCobra94's Avatar
Cooling fans?
I have a set of dual 1400cfm fans they have 2 wires with a T connector my stock fan has 3 wires with a rectangle connector . Do I need to run wiring with a fan switch now ?
ID:	122086   Click image for larger version
Old 08-05-2013, 02:30 PM   #2
92coupe's Avatar
I think the three wires should be a ground a power from the temp switch and a power from the ac you should be able to wire into the temp switch wire onto those fans and they should kick on like factory fans
92coupe is offline   Reply With Quote
09:31 AM
