New trans? - Mustang Evolution
Old 08-06-2013, 10:07 PM   #1
Nwg20's Avatar
New trans?
Hey guys, I have a 85 gt 5 speed and has the common 3rd grind so I'm looking for a new trans. Was wondering what other year trans I could use or other trans then a t-5.
Nwg20 is offline   Reply With Quote
Old 08-06-2013, 10:18 PM   #2
Billymich's Avatar
Well what do you want and what kind of modification do you have currently? Auto or manual. 4speed or 4+OD. Do you want a direct fit? If so get a world class t-5.
Old 08-06-2013, 10:23 PM   #3
Nwg20's Avatar
I actually have a wc-t-5. I've been seeing alot of ranger 5 speeds and v4-6 mustang trans. Needing a replacement for the time being
Old 08-06-2013, 10:32 PM   #4
Billymich's Avatar
Why not just have your trans rebuilt? or if you're up to it, do it yourself !
Old 08-07-2013, 01:36 AM   #5
Nwg20's Avatar
Wouldn't it cost just as much for a used upgrade? And I'm sure doing it myself would be a bit much unless its pretty simple
Old 08-07-2013, 03:50 AM   #6
Get a 90-93 T-5 out of another fox Mustang. Don't pay more than $400. If you don't want to use a T-5 you're going to be looking at a TKO or T-56 and that isn't going to be cheap.
2000 Mustang GT Steeda #0048
Old 08-07-2013, 11:01 AM   #7
Nwg20's Avatar
Well I found one out of a 2000 mustang and I think a 98 but think there both v6 cars
Old 08-07-2013, 12:39 PM   #8
Nwg20's Avatar
I just found a t-56 for 450 with clutch an bell. Wat would I need to put that in the fox?
Old 08-07-2013, 12:58 PM   #9
351stroker's Avatar
My help. Lol.
---------- Post added at 11:58 AM ---------- Previous post was at 11:57 AM ----------
Or sell it to me.
351stroker is offline   Reply With Quote
Old 08-07-2013, 01:10 PM   #10
Nwg20's Avatar
You local? I would love to have a 6-speed in a fox but don't have alot of time for the swap since its out only car an still drives
Old 08-07-2013, 01:44 PM   #11
351stroker's Avatar
No. I'm in Manitoba. Seriously wish I was closer or vice versa. I wrench as a hobby now. Had enough of fixing other people's garbage. I now only work on Stangs. And my own truck.
Old 08-07-2013, 03:35 PM   #12
A Cobra T-56? If its a GM/Viper unit have fun...
Old 08-07-2013, 04:34 PM   #13
Nwg20's Avatar
It's a gm trans. Wish I would find a cobra T for that cheap.
Old 08-07-2013, 08:13 PM   #14
You're going to have a hell of a time with a GM trans... I'd pass and just get a nice T-5 that'll bolt right in and take the power you are making easily.
Old 08-07-2013, 08:45 PM   #15
Nwg20's Avatar
Alright thanks for the info man. Any chance you'd kno why my lights and radio cut out when I push the clutch in to stop? It seems like the rpm drop way to low for anything to stay on
Old 08-07-2013, 09:34 PM   #16
Billymich's Avatar
IAC, bad battery, bad alt. Start by cleaning your IAC, check your TPS and reset your idle. Then test your battery and alternator voltages. That should give you an idea.
---------- Post added at 09:34 PM ---------- Previous post was at 09:33 PM ----------
Wait are you carbed, FI or EFI?
Old 08-07-2013, 09:35 PM   #17
Nwg20's Avatar
Iac an tps on a carb setup? It seems like the rpms drop lower then they should cuz the motor is barley turning over at that point an has even stalled
Old 08-07-2013, 09:37 PM   #18
Billymich's Avatar
Yeah, which is why I jumped to IAC. But then asked if you were carbed, FI or EFI
Old 08-08-2013, 03:14 PM   #19
Nwg20's Avatar
Sorry bout that my fones pretty slow at times. It's a Holley 600 or 650 on a wat looks like a factory ford intake was told all that was done was a e cam but have had plenty e cam cars an this one runs an pulls a bit harder then they did
07:49 AM
