5 lug conversion - Mustang Evolution
Old 08-10-2013, 07:10 PM   #1
87s7's Avatar
Region: Utah
5 lug conversion
Hey guys I'm trying to to do the 5 lug conversion on my 87 fox. I was able to do the front no problem, but I'm having a hard time removing the axle shafts on the rear axle. Any info will be helpful. Thanks.
87s7 is offline   Reply With Quote
Old 08-10-2013, 08:05 PM   #2
93slowstang's Avatar
You need to unbolt the pin in the middle of the diff and slide it out just enough to let the axles slide inward to get the c-clips off. Dont slide the pin out too far or the spider gears will come out and they are a pain to get back in.
Old 08-10-2013, 09:45 PM   #3
87s7's Avatar
Region: Utah
What does the pin look like!? hah
Old 08-10-2013, 10:51 PM   #4
10mm socket should work on the bolt that holds the pin.
Old 08-11-2013, 06:12 PM   #5
87s7's Avatar
Region: Utah
Hey thanks I got it, it was actually a lot easier than I thought! But I have one last question I can't find where to put the oil back in through!?
Old 08-11-2013, 06:19 PM   #6
It will be on the front of the chunk on the driver side. You will need a 3/8 ratchet and extension to get it out.
09:21 PM
