347 stroker - Mustang Evolution
Old 08-12-2013, 02:20 PM   #1
Jcstang's Avatar
347 stroker
What fuel injectors and mass air flow do I need for a 347 stroker are the 24 are enough
Jcstang is offline   Reply With Quote
Old 08-19-2013, 09:36 AM   #2
351stroker's Avatar
I'm building a DSS 347. Gonna use AFR 185's, prob a 36lb injector, Holley systemax 90mm MAF and about 75mm Tbody. Got an AFM N-81 it's kinda big so will need the fuel.
351stroker is offline   Reply With Quote
Old 08-19-2013, 10:00 AM   #3
WhiteCobra94's Avatar
My brother is runnin AFR 225s , 90mm MAF, 42lb injectors
Old 08-20-2013, 06:53 AM   #4
On a 347? Jeez... little big unless he's spinning it at super cray cray RPM.
Old 08-20-2013, 07:24 AM   #5
jduckz5.0's Avatar
Depends...wat u want out of your car 30lb ink. Could b perfect for a street/strip but for more of your big cam and great heads you could 42 or higher....I'd suggest gears also at least a 410 gear/stick,,,456 auto for that big cam...
jduckz5.0 is offline   Reply With Quote
02:02 AM
