new battery keeps dying over night. - Mustang Evolution
Old 08-12-2013, 02:47 PM   #1
88GHOSTFOX's Avatar
My new battery keeps dying in my car over night my alternater is fine. I don't know what the problem is notthing is left on once the car is off I've had 2 people tell me I might have a live wire some where ( something in the car is staying on once the car is off) but can't tell me how to track it down before I got my new battery I had small smoke coming from the ignition one time any suggestions
88GHOSTFOX is offline   Reply With Quote
Old 08-12-2013, 03:07 PM   #2
Kevo91's Avatar
Region: Utah
Is it by chance an optima battery?
Kevo91 is offline   Reply With Quote
Old 08-12-2013, 03:41 PM   #3
88GHOSTFOX's Avatar
I don't believe so but if it is what are my opinions
Old 08-12-2013, 03:43 PM   #4
bigmac3's Avatar
If it's dying overnight, you've really got a big draw. I've left lights on for several hours and still started fine.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 08-12-2013, 03:48 PM   #5
88GHOSTFOX's Avatar
I don't know what too do or what it can be I'm lost
Old 08-12-2013, 03:55 PM   #6
bigmac3's Avatar
I don't know what too do or what it can be I'm lost...
This won't cure your problem but may give you some insight, while the battery is up, disconnect your negative (-) clamp and see if it sparks when touching the post. If you have a draw, it will spark. Then the fun starts in seeing what it is. Sometimes it can be the security system.
Frank
Old 08-12-2013, 04:03 PM   #7
Kevo91's Avatar
Region: Utah
All I can say is if its an optima battery take it back for a refund asap!
Old 08-12-2013, 06:35 PM   #8
lx92coupe's Avatar
There were problems with the ignition switches on foxbodys. The had metal tabs that bent over to hold the guts in the switch. Those tabs would loosen and let the switch try to come apart. I had it happen to a couple of the ones I owned in the past. At one time there was a recall for it. The ignition switch could be failing.
2013 GT Roush Stage1 TVS
lx92coupe is offline   Reply With Quote
Old 08-12-2013, 06:48 PM   #9
lx92coupe's Avatar
The metal tabs (yellow) loosen up and the white part gets loose in the cast housing letting the contacts get out of position If u smelled smoke there it might be worth a look. There were some fires from it
Old 08-12-2013, 07:21 PM   #10
88GHOSTFOX's Avatar
Just took at that they look like they have been replaced already but ill have somebody else look and see what they say about it
Old 08-12-2013, 07:29 PM   #11
lx92coupe's Avatar
If the white part is loose in the cast metal housing the switch is bad. It should not have any movement when u turn the key or squeeze on it
01:59 AM
