Battery reloacation ? - Mustang Evolution
Old 08-13-2013, 05:39 PM   #1
WhiteCobra94's Avatar
How hard is it to relocate my battery to go into the truck? What would I need to do?
Old 08-13-2013, 05:52 PM   #2
Roguestang's Avatar
Best bet is to get a relocation kit from online. You can piece one together, but probably gonna run you about the same to just get the kit.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 08-13-2013, 06:16 PM   #3
Sweet , just looked them up, thanks!!
Old 08-13-2013, 06:19 PM   #4
Roguestang's Avatar
No prob!
Old 08-13-2013, 06:20 PM   #5
Venomouz831's Avatar
Wonder what the pros are for it? I know it looks koo and reduces weight from the front
)02 Gt, Founder of WE2G
Old 08-13-2013, 06:23 PM   #6
Well I was installing my new radiator and I had to take my battery out and I snapped the lock down bolt and couldn't get the battery till I pretty much chopped the Sh*t out of the battery stand / mount that's in the front
Old 08-13-2013, 06:25 PM   #7
Roguestang's Avatar
Well most drag cars have it for weight distribution, and for an easy turn on/off switch on the bumper. Its good to have, but not a necessity for a D.D.
Old 08-13-2013, 06:45 PM   #8
jduckz5.0's Avatar
Takes almost 40lbs out of front end...so helps with understeer also...
jduckz5.0 is offline   Reply With Quote
Old 08-13-2013, 06:47 PM   #9
Well my car isn't a DD , only drove it 544miles last year , so far this year I drove it 358miles lol
Old 08-13-2013, 07:55 PM   #10
1lowGT's Avatar
I thought about doing it with a dd just for ****s and giggles
Old 08-13-2013, 08:00 PM   #11
Roguestang's Avatar
Yeah, nothing wrong with doing it, its relatively cheap (in the grand scheme of things), and will transfer weight to the rear obviously. Lol
Old 08-13-2013, 08:04 PM   #12
1lowGT's Avatar
I might do it sometime
Old 08-13-2013, 09:56 PM   #13
foxbox's Avatar
Actually you offset almost 80 lbs of weight since your moving the weight to the rear of the vehicle which helps with the front to rear weight ratio. I personally have a relocation kit in my fox. It was a not a bad install at all. One of my recent posts has some pics of it. Just make sure you have good grounds; just like everything else. In addition, make sure you keep your pos cable away from harms way. I dont know the difference it will make yet because I still have it up on jacks but it should be done it a few weeks.
foxbox is offline   Reply With Quote
Old 08-14-2013, 06:34 PM   #14
Well if I don't relocate it where can I find a new mount for the front ?
Old 08-14-2013, 07:37 PM   #15
foxbox's Avatar
Your standard issue mustang websites, i.e. cjponyparts, latemodelresto, americanmuscle. You could probably get one at the big box part stores too
Old 08-15-2013, 03:09 AM   #16
92coupe's Avatar
Wrecking yard
92coupe is offline   Reply With Quote
Old 08-15-2013, 03:10 AM   #17
Junkyard
Old 08-18-2013, 09:58 AM   #18
351stroker's Avatar
Relocate. It's simple. U can run the wire under the car. If ur worried about it run it thru some old garden hose. U might want to put a distribution block back there too.
---------- Post added at 09:58 AM ---------- Previous post was at 09:56 AM ----------
U could actually run your solenoid back there too.
351stroker is offline   Reply With Quote
10:35 AM
