Max hp out of gt 40 heads - Mustang Evolution
Old 08-18-2013, 05:41 PM   #1
mike_jay5.0's Avatar
I know it depends on cam injectors and other stuff. But in general how much hp can u squeeze out of gt 40 heads. I've seen only about 280 to the wheels so far
mike_jay5.0 is offline   Reply With Quote
Old 08-18-2013, 05:48 PM   #2
Which version? There are a few. The old iron ones? GT-40p? Aluminum GT-40? GT-40x?
If you can lock the door and walk away without turning back to look, you bought the wrong car.
Finally4190 is offline   Reply With Quote
Old 08-18-2013, 06:04 PM   #3
Iron Gt 40 there bar
Old 08-18-2013, 06:37 PM   #4
300 rwhp should be possible from in injected setup with carefully selected components, 10% more from carbed.
Old 08-18-2013, 06:47 PM   #5
300whp is a factory freak car, most ported GT40 setups can get around 310, box stock ones... probably not.
With a S trim though you can put an easy 450whp to the ground boosting them.
Old 08-18-2013, 09:51 PM   #6
Four Eyes's Avatar
Yeah, out of a bolt on upgrade, you'd probably be looking at 260-280rwhp ish with supporting mods. I'd get the gt40 setup, and put an s trim on it. You keep stock drivability, and stock gas milage if you can stay out of boost.
1986 GT with the typical poor boy mods. 3.73s, Hurst short throw, King Cobra Clutch with aluminum quadrant, lowered two inches on Eibach springs, Hopefully adding some heads and a decent intake soon!
Four Eyes is offline   Reply With Quote
Old 08-19-2013, 08:40 AM   #7
This is what I recommend to everyone who is doing a budget 5.0 build. Gt40 heads/intake from a jy explorer, leave the stock cam alone, upgrade the fuel system, brackets from superchargersonline and a low mileage s trim from the classifieds. Cheaper than a full new HCI and way more power.
Old 08-19-2013, 08:53 AM   #8
Dion11197's Avatar
This is my plan!
Dion11197 is offline   Reply With Quote
Old 08-19-2013, 01:30 PM   #9
I also forgot to mention that you should to the GT40/bolt on stuff first, THEN get the rest of the car ready to handle the 400+whp and THEN do the supercharger. There is a reason a bolt on PI car with suspension work can keep up with a new stock 5.0 at the 1/4 mile. There's also a reason that dudes with 700-800whp GT500s with little/no suspension work wonder whey they can barely run an 11...
05:36 AM
