T5 change - Mustang Evolution
Old 08-25-2013, 09:05 PM   #1
91Bluepony's Avatar
T5 change
Just got a 91 and I think the tranny might be giving out 2nd will grind some times and it whines any ideas?? It's a wc Borg Warner with a beafed up clutch not much details from previous owner
91Bluepony is offline   Reply With Quote
Old 08-25-2013, 09:14 PM   #2
You could try changing the fluid and adjusting your clutch but sounds likes its on the way out. You can find a good used one for $400 or under so I'd just find one and swap it. 2 buddies with a lift can do a trans in an afternoon real easy.
Old 08-25-2013, 09:29 PM   #3
91Bluepony's Avatar
I did it also had a leak...still has a leak...I just put it back together I was hoping there was something else but I figured that was the case. Thanks man
Old 08-26-2013, 08:18 AM   #4
jduckz5.0's Avatar
Sounds like you're low on fluid...tranny might still be good if you add fluid...if you're just grinding sometimes you can have it refurbished for $400 instead of getting a used 1 that might have problems too....change fluid 1st and don't forget the additive ford puts in....check your clutch cable might need adjustment...
jduckz5.0 is offline   Reply With Quote
Old 08-26-2013, 05:00 PM   #5
91Bluepony's Avatar
What about the whining I'm sure that's not good and it's only second that fights me
10:42 AM
