Driveshaft/pinion looseness? - Mustang Evolution
Old 08-27-2013, 09:53 AM   #1
I was taking out the driveshaft on my T-5 and as I was loosening the rear bolts I noticed that it has some play in it. Bolts are tight but best way to describe is if you grab the driveshaft it has some wiggle and you can hear the rear gears clunk. Is this the backlash in the rear diff? How much play should it have? Thanks.
Adam302gt is offline   Reply With Quote
Old 08-28-2013, 07:40 AM   #2
bnoist114's Avatar
Most likely bad u-joint. They will make a clunk when they get wore out
bnoist114 is offline   Reply With Quote
Old 08-28-2013, 11:42 PM   #3
I don't think it is the u joint.. The part coming out of the diff is actually moving.
04:56 PM
