Starter solenoid or starter lost need some help - Mustang Evolution
Old 08-27-2013, 09:26 PM   #1
Muller's Avatar
Hi so the other day jumped in my car after it finished raining whent to start it car fired right up but the starter did not did not disengage . Then I noticed smoke coming from the solenoid. I thought the solenoid was bad so I whent out bought a new one installed it car fired right up turn the car off and tried it again just a loud click tried it several more times and noticed the same smoke as the other time. So I grabbed One more solenoid installed it car fired up three times in a row then stopped and the starter just began growling and sounded like it was barely moving. This being said I had the car on a charger the whole time and the car would not take a charge the voltmeter on the car has been way below what it normally sits at since this all happened. Please helps head hurts from thinking what's wrong thanks
Muller is offline   Reply With Quote
Old 08-27-2013, 09:48 PM   #2
Scott wade's Avatar
I would change starter.
Scott wade is offline   Reply With Quote
Old 08-28-2013, 08:38 AM   #3
bnoist114's Avatar
I would def get starter checked out, but it may be a bad battery also? A dead cell can make some weird stuff happen sometimes
bnoist114 is offline   Reply With Quote
Old 08-28-2013, 05:53 PM   #4
jduckz5.0's Avatar
Check wires on that go to starter,solenoid,battery,and relay/fuses...sounds like you have 2hot wires going to starter and solenoid...a wire could b spliced somewhere then got wet and arched and melted together...instead of 12volts your getting 24volts to them....
jduckz5.0 is offline   Reply With Quote
Old 08-29-2013, 12:16 AM   #5
Muller's Avatar
Yah pulled all my starter cable and negative battery cable and positive cable today
Old 09-02-2013, 10:30 AM   #6
351stroker's Avatar
Your starter is shorted out. Eating the solenoid. Change that POS out before it does some damage to your ring gear.
351stroker is offline   Reply With Quote
Old 09-02-2013, 10:41 AM   #7
Muller's Avatar
Changed the starter and the selinoid car starts awsome now
Old 09-03-2013, 09:14 AM   #8
bnoist114's Avatar
Glad u got ur car starting right again. I went thru alkost same issue awhile back an went thru 4 soleinoids an a starter til I finally worked it out. But glad b u up an runnin now. Electrical an starter problems can be nightmares sometimes
12:27 AM
