Turbo or not? Anybody? - Mustang Evolution
Old 08-27-2013, 09:50 PM   #1
I have an 87 ttop gt.. I am wanting to buy a holset h2 turbo setup on cl to put on my car.. What do you guys think? It was made for a foxbody so it shouldn't be hard .. What kind of gains should I expect? This is what's been done to my car.. . 87 mustang gt with ttops. Bbk cold air intake, bbk long tube headers, and bbk 75 mm throttle body,.. Fuel pressure regulator with gauge .. edelbrock Victor upper and lower intake.. afr 185cc aluminum heads... Flex-a-lite dual electric fans.. 3 core aluminum racing radiator..optima red top battery..coast high performance 347 stroker kit with all forged crank, rods, and pistons...full roller motor with aluminum 1.6 rockers... trick flow stage 2 cam.. tremec tko 500 trans... aluminum driveshaft.. svo rear end with maximum motorsports rear lower control arms and sway bar...3.55 gears.. Aftermarket rims with nitto 555r drag radials...msd 6al ignition, cap, coil and plugs ... underdrive pulleys... Paxton fuel pressure regulator.... Sure there is more I'm forgetting..
Smashleytulsa is offline   Reply With Quote
Old 08-28-2013, 12:15 AM   #2
Pics
Old 08-28-2013, 12:19 AM   #3
Another pic
Old 08-28-2013, 12:27 AM   #4
Pic
Old 08-28-2013, 08:19 AM   #5
DustyStang306's Avatar
You still got the stock block? if so you'll just split it down the lifter valley I would say your probly already in the 400rwhp and about 500 they will split easy if the tunes not perfect and even if it is it won't last long
DustyStang306 is offline   Reply With Quote
Old 08-28-2013, 08:49 AM   #6
Well damn maybe take a bad idea.. With what's on it it has to be pushing 400 already.. Definitely don't want a split block
Old 08-28-2013, 02:55 PM   #7
jduckz5.0's Avatar
Badass car....definitely hit 500hp but as stated stock block won't take that much for too long...I'd definitely put a roll cage and stiffen chassis on a ttop car or you'll be rattling big time...
jduckz5.0 is offline   Reply With Quote
Old 08-28-2013, 03:04 PM   #8
It definitely needs some stiffening ... Need to find some fox guys in my area
Old 08-28-2013, 03:13 PM   #9
And thanks I freaking love it lol
Old 08-28-2013, 03:57 PM   #10
+ 1000000 on a t-top didn't see that
Old 08-28-2013, 04:10 PM   #11
Does the car have subframe connectors?
Old 08-28-2013, 04:21 PM   #12
No not yet
Old 08-28-2013, 04:28 PM   #13
jduckz5.0's Avatar
Those ttops need more than just subframes even with 200hp...lol I had an 87,subframes, torque boxes welded ,Frt and rear strut tower brace and with 300hp it rattled and leaked thru ttops...the best would b atleast 6point for street and 400-500 hp...way too much flex with no roof basically...
---------- Post added at 06:28 PM ---------- Previous post was at 06:24 PM ----------
Heavy front,heavy rear,and the power transfers Frt to back...I'm suprised your doors still open and close...haha but its the most enjoyable and best looking...
Old 08-28-2013, 04:32 PM   #14
Yeah the tops don't leak at all and the doors shut like a new car
Old 08-28-2013, 04:45 PM   #15
jduckz5.0's Avatar
Nice...I would do all the stiffening and suspension mods before I put a turbo on tho...I beat the hell out of mine back when I was 16 maybe that's why mine rattled a lot...haha
Old 08-28-2013, 05:57 PM   #16
Yeah but I'm trading a wrecked car that I have no use for to get it so i won't have any cash out of pocket in the system but I am worried about the block and can anyone tell from the pics of the system if I will need anything else? Looks pretty complete
Old 08-28-2013, 06:37 PM   #17
I was just asking because I'd put them in first then the rest but I wouldn't put a turbo on a stock block 347 stroker that just asking for it to split even at low boost I'd get a aftermarket block for something like that lol the shp dart blocks have a good rep and seem to hold more then there 600hp rating from what I've seen
Old 08-28-2013, 06:43 PM   #18
Well damn tht sucks lol.. Guess I shouldn't then
Old 08-28-2013, 06:44 PM   #19
Ye man Is that a wire by your maf that not hook to anything and what is the black hose going by your ac compressor going to and from?
Old 08-28-2013, 06:50 PM   #20
It doesn't look like your upper rad hose is hooked up
Old 08-28-2013, 06:51 PM   #21
Lol fan wire and overflow hose.. I had the radiator out..
Old 08-28-2013, 06:57 PM   #22
Hahaha ok I was hoping you were not out driving with no rad haha look clean man I don't see anything you need maybe just a dyno so we can see some numbers haha
Old 08-30-2013, 10:23 PM   #23
91Bluepony's Avatar
Jealous of your t-top! She's a hard beauty to find! Good luck with your mods
91Bluepony is offline   Reply With Quote
Old 08-30-2013, 10:31 PM   #24
Thanks man! Wish I could find some foxbody guys around here though ..
Old 08-30-2013, 10:36 PM   #25
91Bluepony's Avatar
From where? And I feel the same way
---------- Post added at 12:36 AM ---------- Previous post was at 12:35 AM ----------
Nevermind just looked up your profile!
03:59 AM
