Window Regulator Motor issue - Mustang Evolution
Old 08-27-2013, 09:57 PM   #1
Region: Nevada
Hello all,
I'm back with another issue. My drivers side window stopped working completely as well as my rear drivers side quarter window. I read a couple of forums and found out that I can remove the window motor and replace the bushings..and that should solve the problem. I did so, but once I mounted the motor back on the mount, I noticed the mount was no longer in the correct position. The spring tension in the center was no longer in place and I now cannot move the mount back in the correct position. I have attached a picture, so you can get a visual.
One picture is the way it is supposed to be positioned and the other is how mine is now positioned. I am unsure of how to keep the tension on the mount without it collapsing back..I am not certain but is there a piece that I might have misplaced that holds the tension of the mount in place. Any help or suggestions would be appreciated. Thanks.
ID:	126206   Click image for larger version
Shelton is offline   Reply With Quote
Old 08-28-2013, 04:56 PM   #2
jduckz5.0's Avatar
Connect some wires to motor and get the position u want then take motor off and reposition it....
jduckz5.0 is offline   Reply With Quote
Old 08-28-2013, 10:21 PM   #3
Region: Nevada
Thanks for the reply, but I wasn't clear on what exactly you suggested I should do. No worries though, I gave in and decided to just order a new window regulator motor since I didn't get any other responses to my inquiry. I guess this is a topic that not too many are familiar with. Again, thanks for your response.
09:56 PM
