Cold start stalling/dying - Mustang Evolution
Old 08-27-2013, 10:01 PM   #1
98slowGT's Avatar
I have a 93lx notch that had a 351w swapp done. Full MSD ignition, with a recent tune up (plugs, wires). When the car starts up from a cold start, it will quickly stall out if not given gas every 3 seconds. Once the car completely warms up its better and wont stall all the time. Ive tried doing some research online and can't really get a straight answer. Any help is greatly appreciated, thanks!
98slowGT is offline   Reply With Quote
Old 08-28-2013, 02:17 AM   #2
M3no956's Avatar
Had the same issue myself, in my mustang the problem was the maf was all dirty ended up buying a new one from CL, try cleaning the maf and see if that fixes your problem
M3no956 is offline   Reply With Quote
Old 08-28-2013, 06:27 AM   #3
jduckz5.0's Avatar
Clean maf.....and coolant temp sensor cold be bad..
jduckz5.0 is offline   Reply With Quote
Old 08-28-2013, 08:36 AM   #4
98slowGT's Avatar
Normally id agree with you but its carbed so I dont have a MAF
Old 08-28-2013, 09:12 AM   #5
jduckz5.0's Avatar
Check temp sensor and vacuum lines....
Old 08-28-2013, 09:26 AM   #6
98slowGT's Avatar
Already did
Old 08-28-2013, 02:49 PM   #7
jduckz5.0's Avatar
Hmmm...did u change anything with plugs??? Different brand or timing??check PVC to see if clogged til oil heats up...try taking air filter and housing off carb and start it also...weird cause thats text book temp sensor symptoms...
---------- Post added at 04:49 PM ---------- Previous post was at 04:48 PM ----------
How old is gas???
Old 08-28-2013, 03:54 PM   #8
98slowGT's Avatar
How old is gas???
I assumed the plugs or wires might have been some part of the cause so I did a full tune up. It only has a problem staying on when its from a cold start, once its around 100 degrees, its fine
---------- Post added at 03:54 PM ---------- Previous post was at 03:52 PM ----------
How old is gas???
And its a daily driver so the gas being old isn't the problem
Old 08-28-2013, 04:07 PM   #9
jduckz5.0's Avatar
Try before u start it to turn key on for like 3 seconds then start it...pressure might not be building from pump enough...also the electric choke could be bad...I'm trying to help bud...lol
Old 08-28-2013, 04:19 PM   #10
98slowGT's Avatar
Hmm, never even thought of that. Thanks! Ill try later on tonight
Old 08-28-2013, 04:30 PM   #11
jduckz5.0's Avatar
Let me know...I'm allin now...lol
Old 08-28-2013, 06:10 PM   #12
98slowGT's Avatar
Just tried it, still just begs to stall out
Old 08-28-2013, 06:19 PM   #13
jduckz5.0's Avatar
If u have help have someone start it while u move the rod on the choke cannister thingy...don't know wat its called...lol
---------- Post added at 08:19 PM ---------- Previous post was at 08:15 PM ----------
Wat coil and plugs??? And wat gap???
Old 08-28-2013, 07:26 PM   #14
jsampson02's Avatar
My 91 did the same thing. I put in a high voltage coil (screamin demon) and gapped iridium plugs to the recommended .060 and cleaned the Air idle control motor. Started up great.
jsampson02 is offline   Reply With Quote
Old 08-28-2013, 07:37 PM   #15
98slowGT's Avatar
Was yours carbed?
Old 08-28-2013, 08:09 PM   #16
jsampson02's Avatar
Originally Posted by 98slowGT View Post
Was yours carbed?
No it's not
Old 08-28-2013, 08:35 PM   #17
98slowGT's Avatar
No it's not
I mean it wouldn't hurt to swap the coil so ill try it, thanks man
12:22 PM
