wire size - Mustang Evolution
Old 08-28-2013, 06:27 AM   #1
jsampson02's Avatar
wire size
I just put in a screamin' demon ignition coil in my 91', new iridiums gapped to .060, should I be concerned with my 8mm wires not being able to handle the voltage/heat?
jsampson02 is offline   Reply With Quote
Old 08-28-2013, 12:07 PM   #2
Not an answer to your question, but why are they gapped to .060? That seems a bit much unless there is a reason like different heads or something.
Adam302gt is offline   Reply With Quote
Old 08-28-2013, 02:46 PM   #3
Roguestang's Avatar
+1
And it could depend on the wires too......
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 08-28-2013, 04:17 PM   #4
jsampson02's Avatar
The demon coil says to gap them between .060 and .065, its almost twice the standard gap but every review is great when the plugs are gapped the way the coil recommended.
Old 08-28-2013, 04:37 PM   #5
jduckz5.0's Avatar
I ran into that with the old accel coil...plugs gapped normally but I was pinging and cold not figure it out til I removed accel...I didn't no it had a recommended gap for plugs back in 90...lol
---------- Post added at 06:37 PM ---------- Previous post was at 06:35 PM ----------
And I think 8mm will b fine but 9mm would be better so I would change just in case....
jduckz5.0 is offline   Reply With Quote
Old 08-28-2013, 05:15 PM   #6
jsampson02's Avatar
Just finished the coil and the plugs. Also cleaned the AIC before starting her up. Ran beautiful, fixed my cold motor stalling issue. It would usually want to stall on the first start of the day or a completely cold motor, had to give it gas for the first 20 seconds or so. So far so good!
10:07 AM
