Good cam for a performer efi intake? - Mustang Evolution
Old 09-02-2013, 05:27 PM   #1
mike_jay5.0's Avatar
I was wondering what is a good ford racing cam for this intake. Engine is a 5.0. Has ac but isn't a daily driver. I leaning toward the f303
mike_jay5.0 is offline   Reply With Quote
Old 09-02-2013, 07:08 PM   #2
Stock until you upgrade the heads.
Old 09-02-2013, 07:31 PM   #3
Of course. I forgot to mention gt 40s fully ported until I can save enough money for afr
Old 09-03-2013, 04:28 PM   #4
Just supercharge and call it a day. You'll spend more money doing the heads/cam and make less power than you would if you threw a s trim at it. Been there/done that.
Old 09-04-2013, 12:51 AM   #5
94gtconvert's Avatar
Would you get a kenne bell blowzilla for 3 grand or a vorteh pro charger for 5 grand? What's better?
94gtconvert is offline   Reply With Quote
Old 09-04-2013, 05:36 AM   #6
Dion11197's Avatar
This is a decision based on your needs and goals for the car. They all have pros and cons. Your twin screw is going to make better torque and power numbers down low..... Your centrifugals are going to make more power up higher in the rpm range and also remain fairly docile at lower RPM's leaving you with very good street characteristics.
Dion11197 is offline   Reply With Quote
Old 09-04-2013, 01:48 PM   #7
5 grand wtf kind of crack pipe are you smoking? Even new the Vortech isn't even close to that much and you can put one together yourself with a low mileage used headunit for around $1500-$1800. Or just find a good used 94/95 kit off the Corral which will be in that price range.
And to answer your question on the 5.0 the Vortech all the way. Can't intercool a Kenne Bell on the pushrod, gotta go with a snow kit or nothing.
Old 09-04-2013, 03:19 PM   #8
Roguestang's Avatar
Agreed. I got my Vortech V3 SCI kit for less than 2K brand new. I think they've gone up alittle in price, and I'm only pushing 4 psi, but runs good without a tune for about a year. But for alittle extra I can buy the parts needed to up the boost. Dont really need much more than 8 psi on a stock block street car anyways.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 09-04-2013, 05:47 PM   #9
Dion11197's Avatar
Yeah, even brand new I think the v3 kits go for around 3k.
Old 09-04-2013, 05:51 PM   #10
Blowzilla vortech which sounds better. Does the blowzilla have that whine like the cobras
Old 09-04-2013, 06:04 PM   #11
Roguestang's Avatar
I thought the Blowzilla was from whipple? Or one of the roots style companies. The whine comes from the roots style blowers. Companies like Vortech, Pro charger, paxton, make centrifugal style. They don't whine like the roots style. More of a sucking sound lol
Old 09-04-2013, 06:27 PM   #12
Dion11197's Avatar
Kenne bell makes the blowzilla and flowzilla. A twos screw and centrifugal are definitely two different sounds!
Old 09-04-2013, 06:49 PM   #13
Roguestang's Avatar
Sure are!
Old 09-04-2013, 07:54 PM   #14
Will the f303 be a good cam with a vortech supercharger
Old 09-04-2013, 08:12 PM   #15
Dion11197's Avatar
Personally I like both. I like the scream of the twin screws at full throttle and I also like the pronounced whistle of the centrifugals at idle.
---------- Post added at 07:12 PM ---------- Previous post was at 07:09 PM ----------
The f cam is probably the best forced induction grind in the FRPP options. There are probably better options in the custom grind market though.
Old 09-04-2013, 09:36 PM   #16
Any good clips I can compair twin screw to centrifugal
Old 09-05-2013, 04:44 AM   #17
Dion11197's Avatar
Yeah, just hit up YouTube. There's a few kenne bell fox's and plenty of vortech, Paxton and procharged fox's on there.
Old 09-05-2013, 07:19 AM   #18
Stock cam dude. With a supercharger you do NOT need to do the cam for block splitting power. Also there are way better grinds out there than the letter cams. The stock cam is actually a very serviceable blower cam.
Old 09-05-2013, 07:37 AM   #19
bnoist114's Avatar
Does anyone kno which would be the best blow thru carb for a supercharger. I have an 85 an don't wana convert to EFI, but I got a good deal on an S-trim. I also like the intercooling effect of the carb, I've jus never ran that setup. Sorry bout the thread jacking, I was jus curious if anyone has experiance with the carb an blower
bnoist114 is offline   Reply With Quote
Old 09-06-2013, 05:09 AM   #20
Dion11197's Avatar
+1! You can take that $200 and put it towards fuel upgrades.
Old 09-06-2013, 08:38 AM   #21
04machazblue's Avatar
If you wanted to do cam go with the Anderson they make decent cams and better then letter..but comp cams makes a program you can instal on your computer that can give a pretty good match to your combo
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 09-06-2013, 06:08 PM   #22
Ment pro charger not vortech's. a new pro charger will run you 5+ grand tho.
06:13 AM
