Passenger window wont go up - Mustang Evolution
Old 09-04-2013, 07:21 AM   #1
91MustangNSB's Avatar
Turned the car off tried to put the window up and it wouldn't go up the volt gauge still goes down a bit when I hit the button what are the necessary steps to figuring out what needs to be fixed or replaced ? Thanks
91MustangNSB is offline   Reply With Quote
Old 09-04-2013, 08:58 AM   #2
351stroker's Avatar
No power to the motor at all? Solenoid will still make the voltmeter jump. Was it slow before?
351stroker is offline   Reply With Quote
Old 09-04-2013, 10:28 AM   #3
It just stopped working I went to put both of the windows up , hit the buttons and the driver one went up and the passenger didn't
Old 09-04-2013, 03:07 PM   #4
351stroker's Avatar
Window motor.
Old 09-05-2013, 11:48 PM   #5
Is there any way that I can test that before I go a head and order one ?
Old 09-05-2013, 11:57 PM   #6
It's not me, it's you.
primer2tone's Avatar
Yeah, your car has a mechanical regulator. They almost never fail. It's gotta be the motor.
Old 09-13-2013, 08:34 AM   #7
So I just got the window motor in 2 days ago but didn't have the chance to install it until last night long story short I didn't have the right size socket to take of the screw that bolt the motor to the door so I gave up. Then I went online and saw that sometimes jiggling the motor and unplugging it and and plugging it back in works. And guess what? It did. So here's my question should I replace the motor or just let it be for now ? Has this happened to anyone else
Old 09-15-2013, 09:15 PM   #8
havhammer's Avatar
Your motor is most likely the culprit if your connection wasn't corroded. Hitting or wiggling the motor just jarred the brushes in it which means you need a new motor, its going out..
havhammer is offline   Reply With Quote
04:01 PM
