Rough idle - Mustang Evolution
Old 09-04-2013, 08:42 PM   #1
Evolution's Avatar
Rough idle
My car has a rough idle, anything lower than 1,400 rpms the engine really shakes. Anything over 1,400rpms, the car rides like it should. I cleaned my maf sensor changed distributor cap and rotor and did and oil change and all that did nothing, any ideas??
Evolution is offline   Reply With Quote
Old 09-04-2013, 08:46 PM   #2
mike_jay5.0's Avatar
Scan codes. Did you unhook the battery recently.
mike_jay5.0 is offline   Reply With Quote
Old 09-05-2013, 12:54 PM   #3
Evolution's Avatar
I tried using a obd code reader but nothing showed up, and I haven't unhooked the battery for probably 5 months.
Old 09-06-2013, 05:39 AM   #4
jduckz5.0's Avatar
Could be the bap sensor...sometimes if tubes r clogged up it won't kick a code...
jduckz5.0 is offline   Reply With Quote
Old 09-06-2013, 08:23 PM   #5
Evolution's Avatar
Just got a sct eliminator chip and my car is now running twice as rough. Shake really hard under 1,200 rpm. What's going on?!
Old 09-06-2013, 08:48 PM   #6
NewMtang's Avatar
Three measures of Gordon's, one of vodka, half a measure of Kina Lillet. Shake it very well until it's ice-cold, then add a large thin slice of lemon peel.
Shaken, not Stirred.
Old 09-06-2013, 10:00 PM   #7
How does it drive when crusing. Does it jerks or surges
Old 09-07-2013, 03:02 AM   #8
Evolution's Avatar
Driving it's fine, drives like it should, over 1,200 it runs like it should but as soon as I push the clutch in and it sits at idle, it's rough.
Old 09-19-2013, 07:49 AM   #9
Last time I had that problem I replaced the pip sensor and adjusted the fuel pressure
Old 10-15-2013, 06:33 PM   #10
Evolution's Avatar
Found out the rough idle was my harmonic balancer, it ended up shaking my engine so bad my transmission cracked, my car was running lean and that was my coolant temp sensor. Running like a beaut
05:36 AM
