Mustang subframe connector bolt on - Mustang Evolution
Old 09-06-2013, 02:40 PM   #1
kickerofdoom's Avatar
On American muscle they have sr bolt on subframe connector for 280 and I was thinking instead of getting the other one and paying for welding to buy these has anyone tried them and are they worth it
Old 09-06-2013, 02:56 PM   #2
Roguestang's Avatar
I haven't used those specifically, but I have bolt-in sfc in both my Stangs. Welded Is definitely better, but I highly recommend them regardless of what you get. My new edge handles like its on rails (although i have other suspension mods), and i havent had any issues with them. Plus down the road, I can always get them welded if I so please. You might be able to find a better deal on C.L. (that's where I got mine from) or ebay. Id check there first, just in case. Just my .02
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 09-06-2013, 06:46 PM   #3
Don't get bolt on ones, they won't do much... Get Steeda or MM full length weld in ones.
Old 09-09-2013, 08:43 AM   #4
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
I think you'll be really happy with the bolt in SR Performance Sub Frame Connectors! Subframe connectors are one of the first modifications that should be done to any uni-body vehicle. This item is designed to stop unwanted chasis flex, while still improving handling! Sub frame connectors are also super easy to install, especially the bolt on kind. They bolt to the engine k-member up front and to the lower control arm bolt and torque box in the rear.
Later down the road if you wanted to improve these even more, you could weld them to the car. The 2004 Mach 1 has bolt on sub frame connectors from the factory and they work great. I ended up welding them to my Mach 1for a little more structural support!
I hope this helps.
-Dan
Old 09-09-2013, 09:08 AM   #5
Roguestang's Avatar
I hope this helps.
-Dan
That's exactly what I did with the bolt ons on my New Edge. Got them from a guy who took them off his Mach 1, and welded them in place
Otherwise I woulda bought them from AM
Old 09-09-2013, 10:24 AM   #6
I like the BBK ones
http://www.summitracing.com/search/p...ame-connectors
01LaserCobra is offline   Reply With Quote
Old 09-10-2013, 03:39 PM   #7
ALWAYS weld. Any excuse of why you didn't weld is bull**** for you not wanting to pay to have them properly installed. Oh and the steedas are the best ones and it isn't even close.
Old 09-10-2013, 11:24 PM   #8
Slow4V's Avatar
People say the SR aren't even full length , and are thin.. Just cheap
You should check out the latemodelresto SVE ones , cheap and very identical to the MM ones ,
If not just get the MM ones
Old 09-11-2013, 01:48 PM   #9
Steedas are like $140 on AM and are the only ones that come with the extra plates for bracing. All the SR stuff is meh.
Old 09-12-2013, 02:23 PM   #10
AmericanMuscle.com
Sponsor
Hey Guys,
These SR Performance Sub Frame connectors are fabricated in the US from chromoly tubing. They're also powder coated for durability and to prevent any corrosion. These are extremely well made and are just as good, if not better than any other bolt on sub frame connector on the market.
I do agree that a bolt on version may not be as affective as a weld in version but it's definitely more convenient and will still make a big difference. Like I said above, if you'd like to weld them in later there's no problem with that!
I hope this helps.
-Dan
Old 09-13-2013, 06:50 PM   #11
Lol convenient... When talking about the structural ridgidity of a vehicle and a safety item you do it the correct way and the correct way only. Any good shop welding in subframes will have you in and out pretty quick not to mention you aren't putting a bunch of holes in your car. There is only one correct way to do subframes and that is to weld them in.
$140 or so for the Steeda units and then another $200-$300 to have them installed by a good shop. No idea why you'd drop double that on units without the extra bracing plates the steedas have and save very little in the end for a far inferior setup.
02:05 PM
