Need some education - Mustang Evolution
Old 09-07-2013, 08:17 PM   #1
Sgt_Syke's Avatar
Need some education
On ford strikers. Com they ask you to select either twisted wedge or inline configuration. Can someone explain this? I've never ordered a crate or short block, or even built a motor from bare block. Thanks
Sgt_Syke is offline   Reply With Quote
Old 09-07-2013, 10:44 PM   #2
Sgt_Syke's Avatar
Correction: Fordstrokers.com
Old 09-08-2013, 09:48 AM   #3
351stroker's Avatar
They are talking about the heads.
351stroker is offline   Reply With Quote
Old 09-08-2013, 10:26 AM   #4
1lowGT's Avatar
Well obviously. What's your question it's not real clear
Old 09-08-2013, 10:45 AM   #5
351stroker's Avatar
Either piston relief or head choice. Can't see anything else.
Old 09-08-2013, 10:46 AM   #6
They are basically asking if you are using trickflow heads, the twisted wedges, or any other head. Trickflows twisted wedge design moves the valves to the center of the cylinder for better combustion. The reason it matters is because piston to valve clearance is much tighter with the twisted wedge heads opposed to a standard head design. But they flow quite a bit more, trickflow 170s will flow similar to AFR 185s.
87fiveoh is offline   Reply With Quote
Old 09-08-2013, 12:24 PM   #7
Sgt_Syke's Avatar
Thanks 87, so I'm guessing afrs or other heads not done by trick flow are inline heads? Are they saying the valve port design is what is twisted? I was planning on using afr's based off a desktop dyno build that a buddy did. I'm guessing then that these are inline?
Old 09-09-2013, 09:42 AM   #8
351stroker's Avatar
Here....
Left twisted wedge right inline.
Old 09-09-2013, 09:44 AM   #9
351stroker's Avatar
They actually place the valve closer to the corresponding port so I believe runner length is straighter ad shorter
Old 09-09-2013, 04:11 PM   #10
Sgt_Syke's Avatar
Thanks for the input. So is trick flow the only man. That does the twisted design?
08:16 AM
