Project 351W - Mustang Evolution
Old 09-07-2013, 07:37 PM   #1
RoCoBass's Avatar
Region: Iowa
Project 351W
Hi everyone! Just bought a '97 F4TE 5.8L to drop into my Sunday driver 91GT over this Winter. My goal is about 450 HP NA. Budget... about 2k. I'd really appreciate advice from those of u who have done this swap before as far as what to avoid & the must haves. I'd like to carry over my ped-mount crane cam 1.7 rr so if u know of some heads to fit those onto please suggest. Other than that I'm all open for suggestions please chime in w/ suggestions and or comments. Thanx
RoCoBass is offline   Reply With Quote
Old 09-08-2013, 09:46 AM   #2
Scott wade's Avatar
I was going to do the same swap this winter. So I will be watching for answer to.
Scott wade is offline   Reply With Quote
Old 09-08-2013, 09:55 AM   #3
Ubnbit's Avatar
Awesome thread Roger. We need to get some of these guys involved. They will be able to tell u everything u need.
Old 09-08-2013, 02:56 PM   #4
RoCoBass's Avatar
Region: Iowa
Nice!
Old 09-08-2013, 03:19 PM   #5
RoCoBass's Avatar
Region: Iowa
Thanx. There are many write-ups w/ helpful info but what really helps is hearing of experiences. We can all learn com each other.
---------- Post added at 04:19 PM ---------- Previous post was at 04:15 PM ----------
My 5.8L is complete, minus alternator, from a '97 F250 w/ 140k mi on it. I will be doing a complete teardown & going on from there.
Old 09-14-2013, 06:21 PM   #6
RoCoBass's Avatar
Region: Iowa
Old 09-14-2013, 06:27 PM   #7
RoCoBass's Avatar
Region: Iowa
Old 09-14-2013, 08:14 PM   #8
Ubnbit's Avatar
Holy crap! Lol
Old 09-15-2013, 08:34 PM   #9
$2k budget? Not even close to what you need even on a super used jy budget build.
Old 09-16-2013, 04:28 AM   #10
Ubnbit's Avatar
What will give roger the best build Scotty? By that i mean, what brands of internals and anything specific he should know?
Old 09-16-2013, 08:13 AM   #11
Well first he needs to come back with a number closer to $5k and that's still bare bones all used stuff.
Old 09-16-2013, 01:00 PM   #12
Yep. 450 hp is going to be damn tough on around 2 grand.
Probably the heads will be the biggest problem...
What are your thoughts on a "long rod" engine for OP Scotty?
I have a "recipe" for one but it requires custom pistons which could be pricey. IDK...
It's been a while since I've even thought about this...If I remember correctly the horsepower came out right around 400...
straybullitt is online now   Reply With Quote
Old 09-16-2013, 01:25 PM   #13
2300turboford's Avatar
+1 my dad put down 450 hp and he has 5k in his with a scat 408 stroker kit afr 185r heads comp cam Harland sharp rockers and a air gap intake
Old 09-16-2013, 04:03 PM   #14
RoCoBass's Avatar
Region: Iowa
Ok I wasn't being too realistic on that 2k tag huh? I can increase that number since project will last till about March. I'm taking block in tomorrow to get checked out & possibly bored out some. Is the stock crank something I wanna keep? Water pump: stndrd flow or high flow? Oil pump, water pump, cam, roller rockers, pistons (oversized?), intake manifold, and heads, dizzy, performance radiatorw/ elect. fan all being new.
This is a learning experience for me & I do appreciate ALL THE INPUT.
---------- Post added at 05:03 PM ---------- Previous post was at 05:01 PM ----------
Funny +1
Old 09-16-2013, 04:04 PM   #15
Ubnbit's Avatar
Scotty, do u have time to lay out the recipe? In the future, I have the thoughts of doing something like this too. Is this not the route to go? If not, what is?
Old 09-16-2013, 04:18 PM   #16
Funny +1
No. Not really.
I was in the Construction business for a long time and I had a rule when writing estimates... Double what you think it's going to cost and you will be a hell of a lot closer to the ACTUAL cost.
If you go to 2300turboford's YouTube channel, Bullitt4571, you can hear the engine that he described above in his dad's Mach 1...
Sounds like music to your ears...
Old 09-16-2013, 04:25 PM   #17
RoCoBass's Avatar
Region: Iowa
Originally Posted by straybullitt View Post
No. Not really.
Cool will do! thought it was funny that I thought it could be done w/ about 2k.
Old 09-16-2013, 04:28 PM   #18
Dreamer...
We'll come up with a good plan for you.
Old 09-16-2013, 06:56 PM   #19
Funny +1
Make sure your shop pulls ALL the cam bearings and checks under there for cracks and any issues. 351 rollers are well known for having cracks under there and yahoo shops don't always pull those bearings and check for whatever reason. As was stated you are going to be in for it for at LEAST $5k. If you are having a shop do the labor, double that to $10k. I would not re-use any stock parts. Get with FordStrokers.com 331-347-408-418-427 Custom Built Small Block Ford Engines and get a rotating assembly. ADperformance and CHP are two others that are very good.
Yeah, 408w, all forged, whatever compression you want to run. MINIMUM 185cc heads, I'd personally go 205cc, custom ground cam and your choice of intake. Again, if you get with one of the builders I listed you'll get a spec'd out combo for whatever you want to make. Avoid any and all ebay parts or cheap crap for your built motor. ARP head studs, good Romac balancer, OEM water pump at the very least etc... Also avoid MSD products. They are the FRAM of the ignition world.
Old 09-16-2013, 07:43 PM   #20
http://youtu.be/77P96zpV3Oc
Old 09-16-2013, 07:43 PM   #21
RoCoBass's Avatar
Region: Iowa
Cool, Scotty. I did read bout cracks under cam bearings. I like that 408 recipe but 1st things 1st... wait 2 c how block checks out.
Old 09-16-2013, 07:45 PM   #22
Originally Posted by 2300turboford View Post
There's my dads 69
Old 09-17-2013, 01:09 AM   #23
RoCoBass's Avatar
Region: Iowa
That Mach1 sounds wicked
Old 09-20-2013, 02:26 PM   #24
mike_jay5.0's Avatar
It's possible to build a 351 on a 2000 budget. Considering you have a complete engine. Get a rebuild kit for about $1000.
mike_jay5.0 is offline   Reply With Quote
Old 09-20-2013, 02:27 PM   #25
Not 450 hp my friend...
Old 09-20-2013, 02:37 PM   #26
DustyStang306's Avatar
+1 lol
DustyStang306 is offline   Reply With Quote
Old 09-20-2013, 04:18 PM   #27
Um no... No it isn't.
Old 09-20-2013, 04:24 PM   #28
Ubnbit's Avatar
Scotty, would he be better off to just buy a crate engine? Scrap the 351?
Old 09-20-2013, 04:29 PM   #29
Depends on his level of skill at putting a motor together honestly. One can DIY it cheaper but you pay the premium for the expertise and peace of mind. His block could very well have cracks under the cam bearings like so many of them do or it could be 100% fine. It will still need to be taken .030 over though.
Old 09-20-2013, 09:45 PM   #30
RoCoBass's Avatar
Region: Iowa
Haven't heard back from the machine shop yet. I'm leaning towards building a 393... but gotta get the word on the block condition. What are your thoughts on a 393, Scotty? I'm a have shop do the bottom end& I'll finish it off.
Old 09-20-2013, 09:50 PM   #31
No reason at all to do a 393 over a 408.
Old 10-10-2013, 05:59 PM   #32
RoCoBass's Avatar
Region: Iowa
I like your thinking Scotty 408 it is. Just got word back from local machinist & my block checked out good w/o cracks Only problem is I spent engine funds on a down payment for a new car. It'll be a month till I can come up w/ $1.5k for Scat stroker kit from CHP...
Old 10-10-2013, 06:04 PM   #33
RoCoBass's Avatar
Region: Iowa
My new car '12 Sonata in background. Maybe I should sell my Monte 2 come up w/ funds for my engine... huh...
Old 10-10-2013, 07:09 PM   #34
Attachment 132096
I'd be all for selling that thing if I were you. I just sold my Mazda 6 for some extra funds to play with but that was to pay off bills. Might have enough left over for a nice upgrade to the Stang but until this upcoming Tax Return season I'm going to be on budget mode.
Old 10-10-2013, 07:41 PM   #35
88GHOSTFOX's Avatar
My brother is getting 420 HP and 470 tq in his 92 GT vert if I remember right he had his stock 302 reinforced the then machine over to a 306 later he put aluminum heads a trickflow intake a b303 cam and a praxton prochager running 8 pounds of boost I'm sure I'm forgetting a lot but these are what I remember ill ask him and report back
88GHOSTFOX is offline   Reply With Quote
» Members Mustangs
Gwen
jamcc
Sheila
nwewing
Add your Mustang
02:39 PM
