Electrical issue battery dies slowly - Mustang Evolution
Old 09-08-2013, 06:55 PM   #1
Foxbody401's Avatar
Having a slight issue. Something keeps drawing my battery down. If I leave it for more than a few days battery is completely drained. Replaced battery and starter relay. Any ideas?.... Thanks
Foxbody401 is offline   Reply With Quote
Old 09-09-2013, 04:37 AM   #2
Mlarv5's Avatar
How I chase these down. Get a good Multimeter and set it to amps and place it between the positive lead and the positive post of the battery. See how much of a draw you are getting. Start pulling fuses until the draw drops to almost nothing. When that happens replace the fuse and start chasing that circuit. Depending on the circuit you will need to either pull plugs or connectors until you find the short. Good Luck plan on a Weekend at least to do this.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 09-09-2013, 07:05 AM   #3
Foxbody401's Avatar
Awesome will definetly try that thanks
Old 09-09-2013, 07:44 AM   #4
Doe_Rae_mi's Avatar
Could be your alternator
Old 09-09-2013, 08:53 AM   #5
351stroker's Avatar
Have an aftermarket stereo? Had a friends car do that to me last summer. He drove it for a month everyday, left
It for a week and it wouldn't start so he kept pulling battery lead so it wouldn't kill the battery. Cant remember how now but we traced it to the head unit. Some genius cut the wiring harness and tapped into everything live. So head unit was always lit up. Never noticed cause he pulled the faceplate off. Needless to say, got a new plug, solder, solder , solder, shrink tube and got an adapter harness now it works good.
351stroker is offline   Reply With Quote
Old 09-09-2013, 09:25 AM   #6
Foxbody401's Avatar
Any way to check if alternator is bad? And I do have an ftermarket stereo but it's wired correctly and shuts off when u turn the key off.
Old 09-09-2013, 09:57 AM   #7
351stroker's Avatar
Capacitor system? Some caps stay on also found that out. Scoche or something like that. The ones with the digital readout.
Old 09-09-2013, 09:57 AM   #8
Roguestang's Avatar
Well I always manually turn off all electronic devices in the car before i turn it off (a/c, stereo, etc...etc..) but use the multi meter to check the votage of the alternator. The 1st reply to the thread was a good idea for sure, and that's what I do too.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 09-09-2013, 10:01 AM   #9
351stroker's Avatar
Hey not to steal any attention from the problem at hand but elaborate on the 3G alternator. I have. Kind of similar problem but alternator reads 14.4 always. Had nothing in the car no stereo nothing and battery kept just going blah.
Old 09-09-2013, 10:02 AM   #10
Accessories can drain the battery even if you turn them off...
01LaserCobra is offline   Reply With Quote
Old 09-09-2013, 04:49 PM   #11
Mlarv5's Avatar
Alternator check. The voltage from the alternator should be around 14 to 15 volts but the only way to know for sure is to take it to an auto store and have them do a load check. For a constant current draw which was the original question the way I described it in the first post is the best way to find it for sure. I have found bad grounds bad plugs on trailer plugs bad stereos tail lights etc this way it has never let me down.
Old 09-09-2013, 07:21 PM   #12
Foxbody401's Avatar
Going to try that tomorrow before I do anything thanks.
Old 09-10-2013, 11:36 AM   #13
04machazblue's Avatar
Had the same problem turned out was the regulator on the alternator
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 09-13-2013, 01:18 PM   #14
Foxbody401's Avatar
Changed the alternator all is good
Old 09-14-2013, 09:40 AM   #15
351stroker's Avatar
Right on. What did you go with? I a thinking about upgrading to 130amp.
04:05 PM
