Gimme some insight on Trick Flow TW and AFR - Mustang Evolution
Old 09-09-2013, 08:47 AM   #1
351stroker's Avatar
I want to hear some input on your uses of either of these heads. Pros and cons. Durability. Use on a stroker if any. This may be a deciding factor in my next purchase so any and all input appreciated. Thanks.
351stroker is offline   Reply With Quote
Old 09-09-2013, 10:48 AM   #2
04machazblue's Avatar
I think best bang for your buck tf's I have a friend who had afrs 185s similar to my set up and I beat him everytime... Both company's make great heads depending on your stroker and what kind of power you plan to make
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 09-09-2013, 11:29 AM   #3
351stroker's Avatar
347 AFM N-81 DSS level 10 block. So far. And as for Hp more is better.
Old 09-09-2013, 02:13 PM   #4
Both tf 205 and afr flow great so you have the bottom end already
Old 09-09-2013, 05:08 PM   #5
Dion11197's Avatar
The new renegade heads from AFR are supposed to out flow the old versions.... The renegade 185's are supposed to equal the older 205's.
Dion11197 is offline   Reply With Quote
Old 09-10-2013, 08:48 PM   #6
Give more info on your build. Either company will have a product to suit your needs just fine. Should be looking at the bigger heads on a 408 stroker for balls shattering power.
Old 09-11-2013, 07:41 AM   #7
351stroker's Avatar
347, DSS level 10 block, AFM N-81 cam( revs to 6700rpm),looking for insight on heads but I want to run a Holley Systemax II intake, prob 80mm tbody, ad a 90mm mass air meter, 34lb inj. Going into a five speed Most likely but I have an auto as a second option.
Old 09-13-2013, 08:44 PM   #8
351stroker's Avatar
Maybe considering the Victor Jr intake. Any opinions??
Old 09-13-2013, 08:56 PM   #9
Consider an aftermarket block or jump up to a 351 block IMO. DSS "level 10" is not good for anymore power than a stocker and if you are planning on revving it high then that's even more of an issue on the stocker. And I have heard every argument for the stuff DSS does to their "level" whatever blocks. All the girdles in the world aren't going to prevent it from splitting right down the lifter valley.
Old 09-13-2013, 09:05 PM   #10
351stroker's Avatar
Lol. $1500 block isn't an option ATM. Plus it's not Gina see the high RPM all the time either. That's just for fun. Car prob won't even see the strip. Lol but what's this about the 351 block?
Old 09-14-2013, 01:23 PM   #11
If your gonna drive It on the street a lot go with the performer rpm air gap plenty if power down low and you can take it to 6500 which good
Old 09-15-2013, 09:13 AM   #12
351stroker's Avatar
Fuel injected not carb setup. Air gap is too small tho. Need bigger like Victor Jr or Holley systemax.
03:59 PM
