93 gt low coolant - Mustang Evolution
Old 09-10-2013, 01:10 PM   #1
Fballman9's Avatar
93 gt low coolant
Okay my 93 gt every thousand miles or couple of months my low coolant light comes on. Recently I changed my heater core, water pump, radiator cap and I see no visible leaks and my oil isn't discolored but this keeps happening any ideas
Fballman9 is offline   Reply With Quote
Old 09-10-2013, 07:06 PM   #2
Kevo91's Avatar
Region: Utah
Is the coolant actually low or does the light just come on?
Kevo91 is offline   Reply With Quote
Old 09-10-2013, 09:47 PM   #3
94gtconvert's Avatar
You may have blown head gaskets, does white smoke come from your tail pipes when its warm out? Does your radiator cap keep burping after warming up. If not the head gaskets, maybe your overflow bottle is cracked, thermostat housing is leaking, radiator is leaking. It can be an assortment of things. I would start by getting the cr nice and hot like a 20 min trip and immediately pop the hood and sniff for the smell of coolant. If you smell coolant it's either the radiator, thermostat housing, hoses, loose drain cock. If you see whit smoke and your cap is hissing at you, you got yourself a blown head gasket. Anyway good luck.
94gtconvert is offline   Reply With Quote
Old 09-11-2013, 04:26 AM   #4
Fballman9's Avatar
Alright thanks
01:22 AM
