Body work - Mustang Evolution
Old 09-11-2013, 03:31 PM   #1
Foxbody401's Avatar
Body work
Good latch is broken and before the hood pins were installed the hood flipped up on the previous owner mangling this section of the car. What is the best way to fix this? Because I can't find that section of sheetmetal anywhere ? Thanks
Foxbody401 is offline   Reply With Quote
Old 09-11-2013, 06:24 PM   #2
Dion11197's Avatar
Can't say I've ever seen it either. A donor car might be your best bet.
Dion11197 is offline   Reply With Quote
Old 09-11-2013, 06:57 PM   #3
jsampson02's Avatar
Same exact thing happen to my car that I had bought. Pull out the dents as much as possible, then start laying in the body filler. Just use a 1 foot body sander to keep it flat.
Comes out pretty good. As long as you get the center bracket pretty straight, spray it blue and the cowl vent will cover it.
jsampson02 is offline   Reply With Quote
Old 09-11-2013, 09:40 PM   #4
Foxbody401's Avatar
Okay thanks ill post pics on here when I do it
Old 09-11-2013, 11:38 PM   #5
351stroker's Avatar
Awe. PO is an effin meathead. It is fixable tho. Spot welder if u can get your hands on one. Hammer and a few different shape hand anvils and it could require minimal body filler. Don't be scared. Start by bringing it all at least up to height or slightly higher so it can be beat back down. Next work on the alignment to the hood the rest is just Mallot work.
Is the wiper post bent??
---------- Post added at 10:38 PM ---------- Previous post was at 10:33 PM ----------
That is nice. Wow our cars clash something fierce. Lol. A side by side would be psychedelic!!
351stroker is offline   Reply With Quote
Old 09-12-2013, 08:06 AM   #6
Foxbody401's Avatar
Looks like i need to buy some tools then and Yeah the wiper post is bent. And about the hood alignment it's an aftermarket fiberglass hood (I'm sure you could see that ) and the hood hinges don't line up with the hood . What can I do about that different hood hinges?
Old 09-12-2013, 09:09 AM   #7
jsampson02's Avatar
I fiberglassed nuts flush into the bottom side of the hood to match the factory hood hinges.
Old 09-12-2013, 09:17 AM   #8
351stroker's Avatar
Are you saying the factory hood hinges are not in the car? What is the hood using? You can buy replacement hinges. Found them on eBay in chrome even.
Old 09-12-2013, 09:58 AM   #9
Foxbody401's Avatar
Ill look into doing this
Old 09-12-2013, 11:04 AM   #10
Foxbody401's Avatar
Hinges are there the holes just don't line up
Old 09-13-2013, 12:02 AM   #11
351stroker's Avatar
Buy new.
Old 09-13-2013, 01:34 AM   #12
Foxbody401's Avatar
Buy new.
How do I know which ones will line up to my hood?
Old 09-13-2013, 09:13 AM   #13
351stroker's Avatar
Hmm. Maybe your hood needs to be drilled if the factory brackets aren't working.
Old 10-18-2013, 06:33 AM   #14
Foxbody401's Avatar
Car is pretty much garaged for the year gonna check this situation out this weekend . Will post with more body issues probably lol
Old 02-09-2014, 11:44 PM   #15
Foxbody401's Avatar
Update on this... Everything is all straightened.. Wipers work again they were just jammed up.. New cowl vent covers middle and sides are pretty straight just time for the body work
04:03 PM
