Shaking - Mustang Evolution
Old 09-14-2013, 01:55 PM   #1
Cblackstang's Avatar
Shaking
Hey guys a get a shake in 5th gear at about 65mph and up..I wanted to ask here before I lift the car and start replacing stuff
Cblackstang is offline   Reply With Quote
Old 09-14-2013, 01:59 PM   #2
Where are you feeling this "shaking"? The steering wheel or your ***?
Old 09-14-2013, 02:08 PM   #3
In the driveline. Gear shift shakes
Old 09-14-2013, 02:19 PM   #4
Ouch!!!
I'm assuming balanced tires, rim not bent, etc. No strange noises...
Check the driveshaft for loose bolts, bad u-joints. May even be out of balance.
I've read of wheel bearings causing vibration also.
Is this something that occurred suddenly, or has it been going on for awhile?
Old 09-14-2013, 02:28 PM   #5
Tires are balanced, rims just recondition and not bent, newer u joints
Old 09-14-2013, 02:40 PM   #6
And did this just start recently?
Jack it up and make sure the driveshaft bolts didn't loosen up...
Old 09-15-2013, 02:35 AM   #7
xxPIKExx's Avatar
I had an SN95 that shook when changing gears and it turned out to be my torque converter. Can't remember now if it was more a shake or grind, but either way.. It wasn't overly cheap
xxPIKExx is offline   Reply With Quote
Old 09-15-2013, 04:28 PM   #8
It's been doing it for about a month..I definitely know its not the torque converter...I'm gonna get it on the lift and see if the u joints are bad already
Old 09-24-2013, 01:21 PM   #9
MustangMatt69's Avatar
Your issue sounds very similar to what my '90 has started doing. Did you ever figure out if it was the u joint or not??
MustangMatt69 is offline   Reply With Quote
Old 09-28-2013, 10:02 AM   #10
86 muscle's Avatar
It can't be a converter unless you have an after market auto...the aod/aode are 4 speeds. Check your d/s bolts at the flange, believe they are a 12 mm...
86 muscle is offline   Reply With Quote
Old 09-28-2013, 09:32 PM   #11
It's a 5 speed...I'm thinking a possible clutch or flywheel..it's only in 5th gear at about 70 it starts to shake
Old 09-28-2013, 09:33 PM   #12
Liebert91stang's Avatar
To me that sounds like a tire balance issue.would think if it was flywheel it would do it regardless
Liebert91stang is offline   Reply With Quote
Old 09-28-2013, 09:36 PM   #13
Yea a tire was my first thought.. I used to work at a tire store so I jumped to that first had my rims checked for balance then sent them off to get reconditioned and then different tires everything came out perfectly balanced and my U joints are still perfect...I was thinking possible clutch cuz I know it's going bad
Old 09-28-2013, 09:39 PM   #14
jduckz5.0's Avatar
Could be the driveshaft is off balance...
jduckz5.0 is offline   Reply With Quote
Old 09-28-2013, 09:41 PM   #15
Yea I guess I never considered that
Old 09-28-2013, 09:51 PM   #16
jduckz5.0's Avatar
Check and see if weights are still on there when you check the ujoints and bolts...
---------- Post added at 10:51 PM ---------- Previous post was at 10:48 PM ----------
If weights are still on I would pull out and see if you have a grove on the yoke also...takes 5minutes to pull a driveshaft...
Old 09-28-2013, 09:52 PM   #17
Yep I'll check in the morning..thanks guys!! Also kinda off topic but I have a syncro going bad between 1st and 2nd..I'm gonna try royal purple syncro max ..anyone every used it before and does it work?
Old 09-28-2013, 10:06 PM   #18
jduckz5.0's Avatar
Never used it but check your tranny mount also...
07:20 AM
