v6 to 302 swap - Mustang Evolution
Old 09-17-2013, 05:28 AM   #1
ProjectTurboV6's Avatar
v6 to 302 swap
I'm pretty sure the engine my dad is giving me is a late 70s carbed 302, I'm only unsure about the year. Ive bought a 4barrel intake and 69 heads that my dad said would raise the compression to 11:1. The guy that sold me the heads said they had some machine work and 3 angle valve jobs. My question is, what do you guys think the engine will produce power wise? And besides a new bellhousing for my t5 and a 8.8 rear, what else will I need to change so that she will run smoothly??
ProjectTurboV6 is offline   Reply With Quote
Old 09-17-2013, 08:57 AM   #2
I really don't think it will be worth the swap
Your 3.7 has more torque as well as more horsepower. Your car is way heavier then the Mustangs that the 302 was installed in.
Of course you can do what you want but I sure would not ruin a good 3.7 (227ci) unless my engine was already puked or something.
But if you decide to do it you can probably sell your 3.7 engine to defray your costs. I would also think of getting a four speed and rear to match the 302 your installing. There are plenty of them in the scrap yards.
Send for a NPD catalog because they have all of the parts you may need for such a swap.
Try this: http://www.npdlink.com/store/catalog...gs-2763-1.html
Old 09-17-2013, 09:05 AM   #3
I have the single port 3.8, 150hp stock, and I've done a true dual exhaust and Bbk cai so maybe 160 to the wheels. That year 302 doesn't even make 200hp??
Old 09-17-2013, 09:57 AM   #4
slow281
sixpac's Avatar
Region: Nebraska
He was thinking a new 3.7
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 09-17-2013, 10:01 AM   #5
I wish I had that! 305hp and 31mpg haha that's superior technology right there
Old 09-17-2013, 10:04 AM   #6
bigmac3's Avatar
That year 302 with a 4bbl will probably get you around 250hp stock. I question the "heads giving you 11:1 compression". The compression in Windsor engines was usually controlled by piston dome shape. If the bottom side of the heads were milled, a small amount of compression increase may be gained but...11:1? Stock was 8.5-9:1. The swap shouldn't be that much of a big deal. Not sure if the bell housing from the six will fit however.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 09-17-2013, 10:11 PM   #7
irishn8's Avatar
Some things you'll want to look into...
Might need a bigger radiator, battery, and beefier suspension.
What mustang is this for?
U should definitely make sure your t5 is the v8 version. The v6 version cant handle the torque of a v8 and the splines wont line up to the engine.
You've probably already thought about motor mounts and such.
Old 09-19-2013, 06:03 PM   #8
I have a 98 v6. But I've thought about the motor mounts, probably gonna find a tubular k member with the mounts I need as well. Now I'm guessing I'll need to pull a gt trans to handle the torque? The only thing I'm worried about is if my fuel lines can handle the extra fuel flow needed so I don't starve the v8, that would be counterproductive haha
Old 09-19-2013, 10:48 PM   #9
irishn8's Avatar
Yes u need a v8 trans and i think ur fuel lines should be ok, might need a better pump though, im not sure on that
Old 09-20-2013, 09:08 PM   #10
i have headers that should fit your car they where installed on a 1995 gt equal length shortys
Ronnysbray is offline   Reply With Quote
08:27 AM
