convertible top issues - Mustang Evolution
Old 09-21-2013, 10:55 AM   #1
Jar72's Avatar
Looked around haven't found info yet on the following issue. Top won't go up or down everything is good relays power switch fuzes everything checks out good. But if I short the switch it works. ( accidental find ). I've trouble shot everything I'm about to jump wire the motor to check it. Any suggestions?
JMF
Jar72 is offline   Reply With Quote
Old 09-21-2013, 06:06 PM   #2
Could it, possibly be the switch itself?
Old 09-21-2013, 06:36 PM   #3
Jar72's Avatar
Its good checked it
JMF
Old 09-21-2013, 06:53 PM   #4
Confusing why when you "short it" the switch works...
I recently had a strange thing like this happen on my truck.
It wouldn't start one day and it was obvious that the fuel pumps,(it has 2 fuel tanks and 2 fuel pumps) weren't working.
Like you I went through everything. It all checked out good. I never thought about the switch that changes the tanks. (Really just turns the pumps on and off) sure enough, the only thing that I was overlooking, was the problem... Bad switch.
Good luck!
Old 09-21-2013, 06:57 PM   #5
94gtconvert's Avatar
Does your car have daytime running lights? I had the same problem because mines from Canada an has a day time running light module shared with the convertible top. Look in front of your front drive side wheel well and there may be a little black box under the horn with a harness in it. This was the source of my headache hope you can find yours. Good luck
94gtconvert is offline   Reply With Quote
Old 10-23-2013, 09:29 PM   #6
Jar72's Avatar
Got it. The p brake switch and very switch were busted. Both test good until power applied. So a 5 buck pep boys rocker and homemade connector. Good as new.
JMF
02:28 AM
